S swerve New member Joined May 21, 2014 Messages 9 Points 6 May 25, 2014 #1 does my fiat punto elx 2001 have a alarm and a immobiliser ?
S s and b Distinguished member Written 5 guides Joined Mar 13, 2011 Messages 7,620 Points 1,453 May 25, 2014 #2 immobilisor yes its in a sealed chip sealed into key no alarm unless retro fitted
OP OP S swerve New member Joined May 21, 2014 Messages 9 Points 6 May 25, 2014 #3 on the key there is hole where the logo should have be will there still be a immobiliser chip
S s and b Distinguished member Written 5 guides Joined Mar 13, 2011 Messages 7,620 Points 1,453 May 25, 2014 #4 swerve said: on the key there is hole where the logo should have be will there still be a immobiliser chip Click to expand... its buried in the key i had the unfortunate luck to have to disect a key earlier this year and broke the glass ferule holding the chip because the key casing was hard and brittle because it was so cold at work look here via atom man https://www.fiatforum.com/punto-mk2-2b-guides/331723-swap-immobiliser-transponder-old-key-new.html
fingers99 Patron member Parked in the garage Written a guide Joined Mar 20, 2006 Messages 27,743 Points 4,560 Location Liverpool May 25, 2014 #5 Without pics, difficult to be sure, but the chip is usually embedded right in the plastic bit of the key.. Best guess, if it's an original FIAT key, and the car starts, no code light, it's in there.
