- Aug 15, 2013
- 457
- 165
Hi guys,
My internal fan / blower on my daughters 02 MK2 has stopped working. I've gone through everything I found on here about the fan and it still doesn't work. The baffling thing is, there is 12 volts at the fan plug. If I take the fan out and hook it straight up to the battery it spins just fine!
Here is what I have done:
1. Took the fan out and hooked it straight up to the battery, it works.
2. Got the multimeter out, I get 12 volts at the fan plug but it doesn't spin the fan! It also doesn't light a bulb (21w indicator bulb)!!!! This is on all 4 fan speeds.
3. I get 12 volts at each of the 4 terminals on the resistor pack in turn.
4. Went to a breakers and tried 3 different resistor packs - no joy.
5. Bridged the earth lead on the other connector as per a few threads on here - no joy.
6. The sidelights don't come on instead.
7. The reversing light works fine.
8. The relays appear to be fine, I've swapped them around and it doesn't make any difference.
Even though I'm getting 12 volts at the fan plug there doesn't appear to be enough current for it to work anything. Could it be all the resistor packs I tried are duff? Could it be the fan switch itself? Could it be the wiring?
TIA
Martin
TIA
Martin
