pdale New member Joined May 8, 2014 Messages 3 Points 1 May 8, 2014 #1 Got punto mk2/2b blupunkt multichanger installed having problem about red 12v wire and brown mute wire off the power cable into my head unit
AndyRKett Distinguished member Parked in the garage Joined May 23, 2011 Messages 14,241 Points 3,356 Location Norfolk UK May 8, 2014 #2 And I presume it's a problem so secret you can't tell us what it is? Little more info might be helpful
OP OP pdale New member Joined May 8, 2014 Messages 3 Points 1 May 8, 2014 #3 the 13 pin cable from the changer installed through the car to the head unit. The blue small block connecter goes in to the head unit but 2 wires are separate 12v red wire and brown mute wire where to connect to
OP OP pdale New member Joined May 8, 2014 Messages 3 Points 1 May 10, 2014 #4 It ok sort it now cheers any way
