Old 05-05-2014   #1
engine cuts out whilst driving 1.2 8v
hi just brought a mk2 punto 1.2 8v (2001) starts up first time but whilst in drive it cut out, first time it started straight back up but after another couple of mins whilst carrying on driving it cuts out again and wouldnt start for at least 10 mins?
could someone please help and what should i check first to try and pinpoint the fault?
im awaiting for the car to be deliverd today, thanks
crummymummy1989 is offline Reply With Quote Quote
Old 05-05-2014   #2
Ziggy122 has donated!
Eggs Champion, Fruit Pairs Champion
Re: engine cuts out whilst driving 1.2 8v
It sounds like the crank sensor ( aka too dead centre) has started to break down
It gets warn and stops providing the critical signal needed
It cools and works again temporarily till it gets toi warm
Its a diy change as well
1x 10mm bolt
1 cabke fitted into casing
1 quick fit connector and done
Ziggy
!!WANTED!! 3dr Mk2 Punto Roof Bars !!WANTED!!
Meet Bumble-Bee
Ziggy122 is offline Reply With Quote Quote
Old 05-05-2014   #3
Burkina Faso (Upper Volta)
see also if theres a load of swarf on the end that sits near the pulley
remove said swarfy
see if any improvement
s and b is offline Reply With Quote Quote
Old 05-05-2014   #4
Quote Originally Posted by s and b View Post
remove said swarfy
sorry can you explain abit more? on what pulley? do you mean on the crankshaft sensor?
Old 05-05-2014   #5
yes
Old 05-05-2014   #6
Trader Rating: 5
fingers99 has donated!
On the crank alternator pulley, at approx 3'o'clock you'll see the TDC sensor.
The standard test for a duff sensor (at least, one that's failing intermittently) is, when it has conked, check for wet smelly of petrol plug, and no spark (both with cranking). If neither, 95% + it's TDC sensor. If either, it ain't.
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 05-05-2014   #7
and if you need to buy one get one from local autofactors like andrew page partco etc
NOt poundland internet sites as you will buy a rubbish copy
Old 09-05-2014   #8
hi again i had a mechanic look at the car and do a diagnostic test but no codes come up? could this be right? also i had other issus like the power steering not working and he put it down to the battery being half dead,, i charged up the battery then started the car and pas started to work,, it wouldnt start straight away as the connection to the crankshaft sensor seems to be dodgy (when i wiggle it it makes a clicking noise near the battery) but now the car wont start at all,, it cranks and sounds like it fires but dont complety start,, just keeps trying to spark by the sound of it but then gives up? any ideas?
Old 09-05-2014   #9
Trader Rating: 5
It's very rare for the TDC (aka crank) sensor to generate fault codes. It's the sensor that tells the ECU that the engine is turning over -- the ECU thinks that if the engine is not turning over, there can be no faults. Such is life.
Did you try pulling a sparkplug (after cranking -- see post #6 )?
Likes crummymummy1989 liked this post
M12 fund 20
Old 09-05-2014   #10
happening to me and it was the crank sensor wire was faulty i wiggle to wire of the crank sensor while the car was running and the engine would cut out steering wasnt working like yours and when replaced the sensor the power steering worked after
goldboy9 is offline Reply With Quote Quote
Old 09-05-2014   #11
Quote Originally Posted by fingers99 View Post
Did you try pulling a sparkplug (after cranking -- see post)?
thanks for the reply i will try them all tomorow and post back with results, cheers
Old 09-05-2014   #12
Quote Originally Posted by goldboy9 View Post
this is your old car i got it of you lol
Old 09-05-2014   #13
oh i see you joined haha! crank sensor mate it was for certain!
Old 09-05-2014   #14
yeah got someone coming tomorow again and hopefully find out how much to get it back on the road,, if too much ill do it in bits with the help from these lot haha
Old 09-05-2014   #15
yeah this is best place to get help haha!
(T) High Engine Coolant Temp - Engine Cuts Out While Driving XuHi Stilo 2 16-09-2013 09:19
Whats wrong with my punto? Engine cuts out while driving! ehmahh Lets Talk FIAT 10 14-04-2011 14:34
(T) 100hp engine squeal/vibration whilst driving at certain rpms Paul82 Panda 2 17-12-2010 16:58
(G) the engine cuts out whilst driving tinaric 500 (Classic) 0 15-04-2010 12:04
(T) HELP! Car cuts out whilst driving lumpylisa Cinquecento / Seicento 7 18-05-2008 22:56
