Hi all,
New to the forum as a poster, but long time reader! I am hoping someone can help. Just to say I have searched the forums, but have not got a clear answer, and not sure the other scenarios match mine. So, here we go!
SYMPTOM:
- Dipped headlights stay on, along with the dipped headlight icon on dashboard, and lights surrounding the heater controls and cigarette lighter.
- Turning lights back to off has no effect. Taking key out has no effect. Fairly certain this is not the 'follow me home' lights feature, as the lights in question are dipped (not main beam) and to be sure I checked/disabled this feature.
- Main beam and full beam both turn off and on as normal; it is the dipped and fan/cig lights that are the problem.
BACKGROUND:
- Worth noting that the lights near my fan controls and cigarette lighter never used to work... Car like that since I bought it.
- Bought a Sony aftermarket radio in Dec. Fitted it as 'normal' merging the red and yellow radio-wires to the single red car-wire (always live). This flattened my battery after a week of the car sitting idle! I read up on the forums here, and discovered the whole "Punto's lack a switched-live cable." issue... Disconnected radio for a few months!
- Yesterday, finally, decided to attempt creating my own switched live by tapping into the cigarette lighter. Could not find a specific guide here for that, but followed the remove console guide (Thanks!)
- Ran a wire from the red/live on back of cigarette lighter up to the yellow connection on radio. Radio worked. It was daylight, so didn't notice anything else amiss!
- During the trial of the above step, I blew a fuse in driver fuse box, I assume it was the cigarette lighter one. Replaced, all ok, but perhaps it relates to my issue, so worth a mention.
- Radio and ignition worked as expected. Radio switched off with car, radio had memory etc.
- Drove yesterday evening, put lights on... Found fan/cig lights now worked! I thought "Bonus!"
- But then found that they and the dimmed lights would not turn off! Only way to do so is to disconnect battery when I leave the car!
- Left battery disconnected over night, and also disconnected radio completely in case that was the cause. Issue still persists with radio disconnected! :-(
- This evening, pulled every fuse out one by one in turn... All fuses ok. But, Lights stayed on! Odd?
- To cap it all, can't find my manual at the mo to check fuse types and roles!
So, not sure where that leaves me! Could a relay or fuse have 'fused' itself to only receive a "one way signal"? I.e. I can turn lights on ok, just not off!
I am hoping this is something that someone here may know about. Has my extra 12v 'tapped' wire caused a permanent issue?
Hopefully this is a fuse or relay swap? (Not entirely sure what a relay is; the bigger red/black blocks by the fuses?)
I'll be massively grateful if someone can help! As I say, no exact scenario or solution seemed to match mine or be available on a search, but apologies in advance if I'm wrong on that!
Thanks! GT
SYMPTOM:
BACKGROUND:
Thanks! GT
