This is my first post as a new owner of a Punto Mk2b.
The factory installed Blaupunkt had a CD failure so I bought an aftermarket JVC KD-R331 CD Radio.
The wiring loom that came with it only had a standard ISO connector.
I disconnected the negative terminal on the car battery first, removed the old unit and connected the new unit's ISO connector to the car ISO connector, then reconnected the negative battery terminal.
There was no power when I connected it, just a CD eject whirring noise. Alongside the standard ISO are mini 20 pin green, blue and yellow mini blocks, are these the power cables? See the pictures attached.
I guess I need some sort of adapter, don't I?
Please help as my daughter drives the car the most and misses playing CD's.
Dean
Dean
