Old 13-02-2014   #1
Malta
Bulb (electric lights) warning but all lights ok ?
More wonder from my astonishing Fiat Punto Mk2. I have a constant light warning sign in my dashboard (amber bulb-like sign) which according Fiat's user manual, it indicates that there is some fault with the electric lights of the car, but all lights are operating well.
Any clues or maybe a wizard?
Stephen505 is offline Reply With Quote Quote
Old 13-02-2014   #2
-~Moderator~-
a1ant's Avatar
Trader Rating: 1
a1ant has donated!
Re: Bulb (electric lights) warning but all lights ok ?
Hi mate,
Have you replaced any bulbs recently? Tail lights for example? Or do you have any LED bulbs fitted?
When does the bulb failure warning light come on? Eg when the sidelights are turned on? Or when the ignition is turned on?
A dodgy earth is another possibility. If you turn your lights on and your hazards ASWELL, if you walk around the car do you see the tail lights or sidelights etc on one particular cluster dimming when the indicator flashes? Or the "Christmas tree" effect of other lights such as revers or brake lights illuminating when say indicator activated?
Alan
If you see a problem post, please click the report button
a1ant is offline Reply With Quote Quote
Old 13-02-2014   #3
Ziggy122 has donated!
Eggs Champion, Fruit Pairs Champion
i have a feeling i owt to make some sort of basic guide for this problem
A lil project for me todo next week me thinks
Ziggy
Thanks oldhammer thanked for this post
Likes homeward, a1ant liked this post
!!WANTED!! 3dr Mk2 Punto Roof Bars !!WANTED!!
Meet Bumble-Bee
Ziggy122 is offline Reply With Quote Quote
Old 14-02-2014   #4
Malta
Hi, The light warning comes immediately on ignition. I don't have the Xmas tree effect (had it and know about it). However I remembered to check few more lights such as that at the back door, the number plate and rear braking light. Checking these I think I would have checked all lights:
Front lights (Dim, Normal, brights and indicator)
Side-front indicator lights (two small amber bulbs)
Cabin roof lights left and right
Rear lights (driving red lights, indicator, brake lights)
Reverse light (one sideo nly on Punto)
Rear number plate
Back door bulb
The ones in Bold are those that I haven't checked.
I have changed the battery (became completely dead) and all bulbs of the head lamps after an accident.
Old 14-02-2014   #5
Westbeef has donated!
Quote Originally Posted by Stephen505 View Post
Rear number plate
Back door bulb
I'd check the brake lights before continuing then.
Westbeef is offline Reply With Quote Quote
Old 14-02-2014   #6
jon1612 has donated!
Quote Originally Posted by Westbeef View Post
that would only cause warning light to come on when brake pressed,
I know been there done that
jon1612 is offline Reply With Quote Quote
Old 14-02-2014   #7
probably the wrong wattage in the rear side lights, most garages / motor factors sell 5W ones they need to be 10W
Likes homeward liked this post
Old 15-02-2014   #8
Malta
Back to square 1: All lights are lighting up (incl. braking lights) and there is no XMAs tree effect when brights are on and the hazards lights are in operation. The only, if I can say, effect I noticed is that with the brights on and hazard lights blinking, when the indicator at the back is on, there is a very very very slight dimming of the rear red driving (always on) light - barely noticeable. What a strange fault?!
How can I check the earth strap?
Dislikes Videophile disliked this post
Old 15-02-2014   #9
Malta
Quote Originally Posted by jon1612 View Post
I never had to replace the rear side bulbs
Old 22-03-2014   #10
Malta
Mechanic said that it was hard to find the fault but finally it was "something wrong" from the rear fog light and told me to avoid pressing the fog lamp switch on the dash board. I am puzzled - I never realised that my punto has fog lamps at the rear and when I press that switch, I never observed any lamp lighting up and thought it was just a fake switch. Well the problem is fixed now
Old 22-03-2014   #11
you're mechanic is a moron
Maker and voice behind the YouTube channel PuntoHowTo 10k subscribers canít be wrong
And now the owner of a shiny new PuntoHowTo Drivetribe
AndyRKett is online now Reply With Quote Quote
Old 23-03-2014   #12
Malta
Yes you are right, i had the Xmas tree effect and that last pin was covered with oxide. His way of cleaning it was to apply some contact spray. I told him that it should be also scraped off a bit but he said there's no need. So now i think the fault was coming back slowly, although no symptoms were yet seen.
Old 23-03-2014   #13
As I mentioned in the video sometimes the fouled pin can cause the connector plug or light to melt or burn around that earth pin this still leaves a very bad connection which can cause the same fault, it could well be you need a new multiplug and earth wire if that's is the case
Old 26-03-2014   #14
Sailing the Second ∆ther
Col Max Pyatnitski has donated!
Ireland
Question on warning light: my lights are all working (visually checked, including brake lights) however I get the bulb-warning light coming on when I press the brakes. This isn't an unknown problem (wiring issues?). Also normal is that if I release the brake the light goes off (makes sense), but the bit that puzzles me is that if I then reapply brakes, the light doesn't in fact come on again.
I haven't managed to quantify how long it takes to "reset" if you know what I mean (i.e. how long after a warning-less brake-application until the warning will reappear). What I am confident of is that when the light does come on, it doesn't go off until I release brake.
Any ideas on cause, implications?
(Was searching forum and read Ziggy's guide, but didn't find answer to this)
Col Max Pyatnitski is offline Reply With Quote Quote
Old 26-03-2014   #15
Quote Originally Posted by Col Max Pyatnitski View Post
Follow my video guide above most likely the cause but very mush boarder line
(T) Rear lights - no tail lights but working brake lights unclebloodyfester Cinquecento / Seicento 2 20-11-2013 11:34
(T) Stop lights come on when headlights are on, bulb failure warning and some rust. Mega Maniac Stilo 3 15-08-2013 18:48
(G) Reversing lights are not working on Sei? Its not the bulb. minidriver Cinquecento / Seicento 3 20-09-2006 18:17
led side lights and the bulb gone warning light dave Leisure Lounge 17 21-08-2005 12:21
(G) rear lights on a weekend, how to change bulb? ChezShells.com Marea 6 11-08-2004 00:01
