you would have to do the shake and vac to put the freshness back
or
when its fitted to the engine start the engine and see if engine rocks back then forwards as it picks up on its own power
this confirms mounting rubber past its best if it moves lots or in gear whilst checking from underneath
with mounting off you can only look for delamination
The real trick would be to build a jig from a new one, burn and blast the old one, and use a polyurethane resin to re-cast the innards, but it's much more work than Sikka or replacing with an OE one. For race use only!
this is from my stockl
i certainly would fit it
sickaflex is ok but a bodge at best if rear bolt not coming out
well euro turned out to be waste of time,
they dont have any.. engine mounts
got one orderd. brand new oem part using forum deals thing on here,
worked out cheap,
+ cheaper than buying 2nd hand tat off ebay..
Sounds like plenty on back and forth motion when undoing the bolt....
Impact would make light work of it tho
Ziggy
ah well its fitted..what a nightmare getting that 18mm bolt out
broke 2 breaker bars, :bang:
went through a period of these breaker bars breaking
one nearly did me a bad injury
i really dont use mine in a situation where i dont know if it will break without warning anymore
i use short arm with scaffold pole in
impact gun
or a cracking bar on commercials
looked on the web and the wurth one looks good
my last one came from partco/brown brothers
