This kind of problem is now with the Punto. RPM is limited to 2500 rounds. Mil lights up every time you give enough gas, but not in memory FiatMultiEcuScan found nothing. Car driven 130 000 km.
T.e done so far:
-plugs and ignition wires replaced, no effect
-checking out the exhaust pipe from start to finish, not blocked
-sensors values checked tester-> ok
-ECU changed about 20tkm ago
-connectors and components checked
-pressures on gasoline-> ok
-pressings measured
-manifold has not yet been removed, but the mirror trying to look for possible cracks
The plugs must swim really fast after the exchange might be related in some way to this problem ...
A lot of these problems Puntos written about, but I certainly would not have found this a suitable case. If one of the forum have experience or good tips, so any advice will be well received!
ECU problem??
T.e done so far:
-pressings measured
ECU problem??
