Where is ur oil warning light? Assuming ur only on ignition and the engine hasnt been running before hand....
Ziggy
Good spot ziggy :thumbup: I intentionally made sure the oil light doesn't work to see if anyone would notice...........:banghead:
Ziggy
looks nice,Smd leds finally installed after much frustration! Well worth it tho! :thumbup:
looks nice,
im happy with the standard tango ones,
makes the car feel warmer on the cold nights,
Did you find out why the handbrake light was flicking on and off? Mine also does this!
Thanks.
Stacey
Thanks.
Stacey
arches look good mate,
get some half wheel arch liner's off basic punto,
it stops the ming flying up and onto inside of bumper and wheel well,
first thing ifitted after cleaning mine up,
how did you get on with the heater dials?
Got some new ngk plugs and ht leads today, just fitted them, old plugs weren't too bad - sort of a chocolate colour, probably won't notice a difference but sometimes that's a good thing!
Although on one of the old leads there was a massive splice in the wire, although I'm not sure if this was from me removing it
are the new ones iridium?
16v will soon wipe em out if not,
not cheap these but is'pose they last a few years,
They certainly are iridium ones, hopefully I notice 'em
Nope not cheap at all this 16v is it
nope deffo not cheap for part's.
mines cost me a small fortune, so far since igot it ive spent, just over 950
the little bits soon add up,
Its the drivers wheel arch you need to worry about more vs the passenger
The fuel tank holder is a swine for muck and moisture holding
Mine was thick and stuck like glue, needed some serious chiesel tapping off to release it all
And then the arch....
If the arch's are clean, give them a spray with some black stone chip / waxy oyl / underseal
A - it looks very smart imo, but 2 it protects as well
Also - newest youngest more tread / better branded rule kick in here - which should go on the rear
Why? Bum slides are not cool in FWD cars, and the rear has to regain traction before the fronts before control is returned
plus understeer is soo much more control-able then you think Also Candiance braking is the way to go
Ziggy
good result.
mine went straight through on the mot last year..im hoping iget same result
this year.
1. Offside rear shock absorber slightly worn bush
=Replace as a pair.
2. Nearside and offside front brake hose slightly deteriorated
=Replace with new ones.
3. Parking brake efficiency only just met, requires repair or adjustment : 16%!
Drums off check shoes/clean adjust or replace.
4. Front exhaust support bracket broken
remove it fully or replace ...what isnt there carnt fail my mate the mot tester once said.
5. Rear exhaust silencer deteriorating
replace it.
shockers & shoes & back box id grab off ecp..
