Thread Tools
Old 16-01-2014   #1
Revving while clutch in.
Chaps,
Just been driving my 2005 Punto, and noticed that while the car is driving, at any speed, if I put the clutch in, the revs jump around 1000rpm.
The problem isn't there when the car is stationary.
I've had a little look around on here and other forums, and one post point me towards a sticking throttle body. Does this sound possible?
I've noticed that when the car starts, initially coming out of 1st and 2nd gear, the car is very juddery when I'm accelerating hard, even if the clutch isn't pushed in. It does continue in the higher gears, but less noticeable.
Checked the fault codes, and all I've got is a misfire on cylinder 3, which I'm aware of, and just waiting for the leads to arrive to fix this.
While I'm here, when I'm looking into the engine bay, from left to right, do the cyclinders go;
4-3-2-1?
Thanks in advance for your help.
Rogo is offline Reply With Quote Quote
Old 16-01-2014   #2
Sailing the Second Ęther
Col Max Pyatnitski has donated!
Ireland
Re: Revving while clutch in.
I thought cylinder 1 was the one by the timing belt (you won't see the belt, but you'll see the plastic cover, same side as the dipstick for oil). I think the cylinder numbers are supposed to be marked somewhere near where the coils are, so you could trace the HT leads back to double check.
Col Max Pyatnitski is offline Reply With Quote Quote
Old 16-01-2014   #3
Ziggy122 has donated!
Eggs Champion, Fruit Pairs Champion
Quote Originally Posted by Col Max Pyatnitski View Post
Yes in the punto's case Cyl1 is belt end cyl1 is coil pack end
Not all cars are like this tho! French aren't, there flywheel based cyl1, well it was on a stupid clio anyway
Do you have a 8v or 16v?
if its 8v, a gummed up throttle body yes - cheap and easy todo
16v, worth a clean, but its fly-by-wire, no cable, so it controlled by a motor via the ecu
Ziggy
!!WANTED!! 3dr Mk2 Punto Roof Bars !!WANTED!!
Meet Bumble-Bee
Ziggy122 is offline Reply With Quote Quote
Old 16-01-2014   #4
Trader Rating: 5
fingers99 has donated!
The cylinders go 1,2,3,4 from the timing belt end. You're thinking of the "firing order" (you don't need to worry about that.)
Assuming you have 2 coil packs, leads from 1 and 4 go to one coil, 2 and 3 to the other.
Again, assuming a throttle body with a cable, fluctuating idle is usually down to a vacuum leak (at the throttle body or closer to the engine) or to a dirty throttle body.
M12 fund £20
fingers99 is offline Reply With Quote Quote
Old 16-01-2014   #5
Burkina Faso (Upper Volta)
Quote Originally Posted by Rogo View Post
Chaps,
4-3-2-1?
your seriously running the car with a missfire thats due to a faulty ht lead?
oh dear, no wonder these cars get a reputation for failed ecus
next.............
s and b is offline Reply With Quote Quote
Old 16-01-2014   #6
Yeah, you're right, I should just walk the 20 mile round trip to work, in winter, while I wait for the new HT lead to arrive.
Fingers, CMP, and Ziggy thanks for your helpful answers. I'll clean it up tomorrow.
Old 17-01-2014   #7
T-Jet!
Sweex's Avatar
Sweex has donated!
Im sorry, he is right. That wasted spark from the coil has to go somewhere and they normally spike back to the ecu. So the cost of a bus will be much cheaper then a new or secondhand ecu with new lockset...
Likes oldhammer liked this post
My Grande Punto T-Jet Daisy
Sweex is offline Reply With Quote Quote
Thread Tools
(T) 1.6 only revving to 2k richydraper Stilo 4 02-05-2012 14:26
(T) over revving gbchinq Cinquecento / Seicento 2 22-10-2008 11:29
(G) 2003 1.2 8v Active Punto - clutch prob? Odd revving?? Please help!!..I'm a girl!! ;o) Rokitgrrl Punto (Mk2/2b) 11 30-09-2008 21:08
(T) Clutch woes and Engine Revving Xen Punto (Mk2/2b) 4 28-06-2008 00:11
(T) Self Revving... CrazyArchie Cinquecento / Seicento 4 20-01-2005 15:00
