Old 07-01-2014   #1
Italy
Drivers Seat Back Collapsing
So was driving along in the car yesterday when there was a clunk and the left hand side (as you sit in it) of the drivers seat back collapsed a bit.
The seat back is still upright but there is a definite 'lean' to the left on the seat back and it does appear to be looser around the mechanism than the right hand side of the seat (at the bit covered by the plastic casing with ratchet handle for adjusting the angle of the seat back.)
Have had a bit of a poke about but can't see anything obvious. Anyone got any ideas?
Thanks!
danharwood is offline Reply With Quote Quote
Old 07-01-2014   #2
jon1612 has donated!
Re: Drivers Seat Back Collapsing
Quote Originally Posted by danharwood View Post
Thanks!
I would try adjusting seat in every position to see if it cures it. otherwise sounds like you need to get another seat from the scrappers
Likes danharwood liked this post
jon1612 is offline Reply With Quote Quote
Old 08-01-2014   #3
jonik has donated!
Finland
There is four torx bolts under the plastics holding the seat back in place. They become loose over time, tighten them up and everything should be fine.
Likes danharwood, jon1612, homeward liked this post
jonik is offline Reply With Quote Quote
Old 08-01-2014   #4
Burkina Faso (Upper Volta)
usually seats are unmendable when they get like this i find
Likes danharwood, oldhammer liked this post
s and b is offline Reply With Quote Quote
Old 10-01-2014   #5
Italy
Quote Originally Posted by jonik View Post
Thanks for this suggestion, I'll give that a go this weekend - I don't suppose you know how to get the plastic cover off do you? It's the side that has the handle to adjust the seat back angle.
Old 10-01-2014   #6
jonik has donated!
Finland
You can just pop it out. If it's 3d, you must remove center cap first. There is two screws holding the plastic in place. It's a bit tight to get out because of the seat belt lock.
I bought 5d seats from better equipped model to my 3d Punto so had to strip them to get the frames changed.
Old 11-01-2014   #7
Italy
I had a go at this today - found the offending bolt - tried to tighten it up but wouldn't tighten enough stop seat back still moving.
On closer inspection I removed the nut and as in picture below you can see that it was spot welded on - reckon the spot welds breaking was the clunking noise when seat back first went.
All I need to do now is figure out a way to reattach the nut to the frame!
Old 11-01-2014   #8
get a seat mate
ive nearly lost fingers messing with these
you can always swap the seat squab and the rear cover over to the replacement if you wish, im sure therers a sticky on it in guides and it only takes an hour tops
(G) Upholstery on back of drivers seat undone (Sport Seats) maiod Bravo 4 29-09-2013 20:10
(G) Check under your drivers seat-Seat trim weird fault on 2008 chequered cloth Elio 500 35 29-01-2012 14:58
(T) Rear Suspension Collapsing? Nicky T Multipla 6 06-08-2008 00:13
(T) Seats Collapsing!!! NumanR Stilo 12 09-03-2006 22:56
