Thread Tools
Old 01-01-2014   #1
55 1.9 Diesel power steering fault
For a few months, every now and then after about an hours and a half, the power steering would fail with associated warning light. By turning off the ignition, then back on again it would clear and not return.
This morning, I get the warning light but the steering appears normal! Turning the car off and then on again will only clear the warning light for a few seconds.
Anyone know what the problem might be?
Jamie Haggo is offline Reply With Quote Quote
Old 01-01-2014   #2
-~Moderator~-
a1ant's Avatar
Trader Rating: 1
a1ant has donated!
Re: 55 1.9 Diesel power steering fault
Hi mate, and WELCOME TO THE FORUM
There are several things it could be, so a good place to start would be to have the codes read and then post them up here.
You could do it yourself with Multi ECU Scan and the appropriate cable on a laptop, or if you post your location, maybe someone close to you may be able to assist.
A common cause of EPS problems particularly at this time of year is a weak battery. So its also worth having your battery properly tested. There are lots of places that will do this for you for free. However to me your problem sounds like it may be more than a weak battery.
Alan
If you see a problem post, please click the report button
a1ant is offline Reply With Quote Quote
Thread Tools
(T) Power steering fault viadevana Ulysse 4 11-11-2012 23:16
(T) power steering fault Mark H Punto (Mk2/2b) 10 05-04-2011 20:12
(G) Power Steering Fault cosso1 Stilo 24 16-03-2010 01:56
(T) power steering fault bridges Punto (Mk2/2b) 0 07-12-2008 14:30
