Hi Guys,
I was hoping my first technical thread wouldn't have come so soon, but here we are. Hopefully someone can guide me in the right direction, or at least confirm my suspicions are correct.
I purchased a 1.2 8v 54 Plate Punto about 3 weeks ago, from a dealer who had taken it in part Exchange. Everything seemed okay, it drove well upon test and the dealer delivered it to me after taxing it.
I drove it around a little for a few days (no more than half a hour at a time) and one trip on the motorway of about 40 miles and all was well. Until last week.
I was picking someone up, and they were putting stuff in my boot. I had the car running and after about 10minutes of so of being sat still, we set off. As we reached the top of a small sloped road there was a massive amount of steam coming from the front right, under the bonnet. I shut off the Engine and noticed it was quite higher than normal (about 3/4). I lifted the bonnet and noticed all the steam was coming from the bottom on the right side of the radiator (if sat in drivers seat). After that I wanted for it to cool down and limped it home.
It's been sat for the last week or so as I've not had time to look at it. What I have found is that the radiator fan is not kicking in. I've removed it and cleaned the housing as well as replaced the fuse but still nothing. I then applied 12v to it directly and it's not coming to life at all.
I checked the min/max marked bottle on the radiator and couldn't see any coolant in it at all - Could've just been dirty, so I topped it up until it was full (perhaps a bit too full) and ran the engine, waited a while and checked it again. Coolant was coming from under the lid and eventually sub-sided. I let the Engine cool down before opening it again, and again couldn't see it between the min max marker.
I took it for a drive and it was staying steady at the halfway mark on the temperature dial, but I noticed that the heaters were not pumping out hot air at all.
In addition to that - the power steering icon has popped up on the dash as well. Though the steering itself seems fine.
So I was wondering if anyone could tell me whether or not it is likely I have damaged the car by allowing it to overheat? It certainly wasn't a long period of time, but could I have damaged the head gasket? I know that cold-air only from the heater is a potential sign!
In relation to the steering wheel light- could this be a battery issue? I've seen it crop up a few times on the forum, but it only came on after I've allowed the car to sit for a couple of days during this relatively mild winter.
Thanks in advance.
Anthony.
TL: DR - Cooling fan not working, overheated car until steam came out the front, took it home, let it sit for a couple of days. Now heating fans are cold, and steering light is on permanently, though the steering is fine. All-related? or have I bought a dude. Where to start for a resolution?
Thanks in advance.
Anthony.
