mikeypunto84
- Nov 27, 2013
- 14
- 4
Noticed a small oil leak the other day and found my sump is quite badly rusted. I live in hull and its a 2004 1.2 8v, just wondering how much id be looking at to have it replaced??
Had this done the other week, £30 for the sump and sealant, 2 hours labour at £40, 3/5 job unless bolts, etc misbehave.
Strangely they didn't change the oil filter which quite frankly is odd..
becoz you have paid for fitting of sump and not a service
did you expect them to polish it and hoover it out n all
Even though I supplied them with fresh oil and a new filter for when they change the oil, changed the oil but ignored the filter.
Seems a pretty obvious thing to fit a new filter when replacing oil, even discussed it with them beforehand.
Funnily enough, they did actually hoover and polish my car, impressive
Worth checking that the oil leak is a result of the rust. It's not uncommon for any oil leak above the sump to drip down, in which case, sort that, scrape off and treat the rust, paint.
Fair comment
you didn't say in your post that you supplied them with oil and filter
or my comment wouid of been different..
your lucky you supplied your own oil many a garage out there wouid just throw the old oil back in rust n all seen it done.
as for filter change.. yeah they shouida done it if you asked them too
