Technical Winter tyres
I still use Vredstine SnowTrac3's myself. If I had to use one of the three you've linked though it would be the Avons as I use their summer rubber sometimes and have always been pleased :)
Cheers guys (y) I've noticed most of those tyres you linked have been tested alot by various people. I guess real life testing is a much better statistic to look at compared to the A-G rating label system
Wrightyy
Uniroyal MS plus 6
Had a set on the rear last year, it make it alot more stable on slusshy stuff and snow, it meant i could control speed 10x better downhills with my handbrake :)
This year - its a full set :) BRING ON THE SNOW!
If all else fails - i've got chains :)
quick scurry around found them cheaper on Camskill :)
However - they are out of stock at the moment....
Ziggy
wow where do some of you guys live? ive lived all over the country all weathers and never needed winter tyres on a front wheel drive car especially so i can pull the handbrake on on a hill,hell in the winter of 1980 i was the only vehicle that bad january that made it up the a1 and that was in a rear wheel drive mk1 escort van with 145x12 tyres on,ok i had to dig the van out once near boroughbridge but still made it to durham albeit with a ton of ice formed on my pancake airfilter and a fuel gauge dropping as i drove:D
i know compounds have changed but the art is in control not how good a tread pattern you have
The most significant thing is probably that 145 number. Our old Minor 1000 would fly around in the snow when modern cars were skating past us. If anyone is going the winter tyre route I suggest you get a set of steelies and fit the narrowest tyre approved for the car.
:rolleyes: winter tyres are not all about going through snow, they are better at stopping
Do check. I've seen this mashing on Centos.
The only mashed up part is when i didnt rehook the bottom of the shoes and it ate part of the centre hub to no ill effect....
Now
Either im a lucky sod
The bolts are only just catching on 1 set of wheels
or magic trolls are afoot!
Didnt have any issues with the steel wheels and bolts last year on steelies tho?
Ziggy
