Penetrating oil, 6 point socket, chances are the studs will come out (but you can free them up with the old 2 nut trick -- soak in penetrating fluid overnight).
Generally you find that while the nut will seize onto the stud (both being steel) the stud won't seize to the aluminium alloy head.
If you use "real" heat you'll pretty much destroy any temper the nuts/studs have.
