Old 15-09-2013   #1
grapeman has donated!
Cooking cookies Champion
Question Engine Light On - P1691 Code (Seeking opinions & experience)
About a week ago I drove 60ish miles and no problem. Car has been sat on the drive for about a week and now has the engine light on. It is rather hard to get started (you hear it try 2/3 times before finally firing up). Took it out for a drive around the block, but couldn't feel/hear/see anything out of the ordinary (other than the engine light).
My OBD reader has detected P1691 which, from reading other threads and Google, could be any of the following:
  1. Safety cut-off from controller
  2. Safety Cut off - Secure shutdown
  3. Secure Breakdown
Unfortunately these threads don't conclude in any obvious solution - hopefully this one can .
It's been suggested it may be the MAP sensor or throttle control. What can you suggest?
grapeman is offline Reply With Quote Quote
Old 15-09-2013   #2
-~Moderator~-
a1ant's Avatar
Trader Rating: 1
a1ant has donated!
Re: Engine Light On - P1691 Code (Seeking opinions & experience)
Hi and WELCOME TO THE FORUM!
Does your obd reader have live data so that you can look at the MAP sensor readings and the TPS readings?
P1691 is one of those codes that has various different causes rather than pinpointing one, however the majority are linked to the throttle body.
You could also try a throttle body clean and re-learn procedure, as it will cost you nothing.
Have a look at these threads for more info.
Link
Link
Alan
If you see a problem post, please click the report button
a1ant is offline Reply With Quote Quote
Old 15-09-2013   #3
Forum Moderator
T14086's Avatar
T14086 has donated!
P1xxx codes are manufacturer specific so you will need to find out from a Fiat dealership what the code is or have access to these manufacturers (Fiats) codes or use Fiat diagnostic equipment.
Old 15-09-2013   #4
Likes LukeEssex liked this post
[CENTER]-------=_FIAT_=------[/CENTER]
bigbrava is offline Reply With Quote Quote
Old 17-09-2013   #5
Thanks for the welcome!
Sadly this problem has developed into something far more serious. I have now got the code P0115 - Engine Coolant Temperature Circuit Malfunction and the car will not start - just tries to turn over but never gets there.
I am currently suspecting the head gasket has gone because the engine coolant visibly rises each time the engine tries to turn over. I'm going to do a compression test tomorrow to try and confirm. Has anyone had any experience with this?
Old 17-09-2013   #6
Trader Rating: 5
fingers99 has donated!
Really, compression testing is easy. Just -- charge the battery the night before -- remove all the plugs, unplug the TDC sensor (on Mk2s it's usually on a plate by cam cover), screw in the comp tester to plug nearest the timing side (#1 cylinder), get your assistant to hold the throttle wide open and crank the engine (about 5 revolutions of the motor). Write down the reading, continue, post results.
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 17-09-2013   #7
Ziggy122 has donated!
Eggs Champion, Fruit Pairs Champion
Autodata lists
P1691 Fiat specific
Fuel shut-off control - malfunction
Wiring, poor connection, fuel pump (FP) relay, throttle control unit, ECM
in basic terms
Check plugs for fuel cut off - fuel pump - the connections to the throttle body and the earthing strap on that
Check the relay for the fuel pump (energise low current side) and then check resistance across High current
The throttle control unit is the throttle body
p0115
is yes looking at the CTS
To test it
When coolant is 10C the resistance across the 2 pins should be around 3800ohms resistance
When its hot at 90c it should be low around 230ohms
Sensor sometimes fail, but not often, its also worthwhile checking the wiring
A daft thought, but have you tried removed the ECU connections - giving them some contact cleaner and refitting
it could be easily a simple wiring fault here
Ziggy
!!WANTED!! 3dr Mk2 Punto Roof Bars !!WANTED!!
Meet Bumble-Bee
Ziggy122 is offline Reply With Quote Quote
Old 17-09-2013   #8
grapeman can you tell me the exact model you have including engine size and whether its man or automatic and year i have been doing some digging for you and need a bit more info to finally give you answers as i personally do not think your head gasket has gone.
Old 17-09-2013   #9
Ye sure. It's a 5 door 2001 16V 1.2L Manual Petrol
Likes bigbrava liked this post
Old 17-09-2013   #10
ok thanks watch this space
Old 17-09-2013   #11
grapeman i have done some extensive reading of approx 3200 pages of fiat (special docs)
lets just say for now fiat dont like the public having them, however after routing through i need to know the following before i can give you the answer/diagnosis that you need.
things i need to know is: when you just turn on the ignition does the fuel pump prime for about 2 to 4 secs then go off?
if the pump does, then does your engine fire periodically when trying to start?
if it does fire then is like a promising fire where it almost seems like it will run or is it a very feeble or slight engine fire?
in advance of you giving me these answers above i also need you to leave the spark plugs in but disconnect the plug leads (all of them but label them before you do so you know which lead belongs to which plug) then i need you to insert a plug into every lead and let me know if they all fire as they should when turning it over.
once i have all this info i should have your answer.
Thanks grapeman thanked for this post
Old 18-09-2013   #12
atom0007 has donated!
3200 pages.....looking forward to the answer.
Likes a1ant, homeward liked this post
atom0007 is offline Reply With Quote Quote
Old 18-09-2013   #13
Quote Originally Posted by atom0007 View Post
and its a one word answer - i'd piss myself
#broken
Ziggy
Likes atom0007, a1ant, homeward liked this post
Meet Bumble-Bee
Old 18-09-2013   #14
-~Moderator~-
a1ant's Avatar
Trader Rating: 1
a1ant has donated!
Me too!
Ive only come across it a handfull of times and it will be fun to successfully diagnose without Examiner!
I think the problem may lay elsewhere but ill hold on that for now as bigbrava sounds like he's on to something.
Goodluck!
Alan
Old 25-09-2013   #15
Thumbs up Re: Engine Light On - P1691 Code (Seeking opinions & experience)
Hi guys,
First off, apologies for the delay in getting back - it's been a rather hectic few days.
I was recommended by a friend, who's a bit of a petrol head , to have it looked and quoted by a local garage as he too thought it was the head gasket. So I booked it into a garage and they confirmed the head had indeed gone. They replaced and skimmed the head, replaced a leaking water pump and all the sparks as they had become brittle from the excess heat.
So all in all theses were the issues:
  1. Head gasket blown
  2. Water pump leaking
  3. Heat damage to plugs and plug leads
Got to car back today and all is running smoothly. Little disappointed with the ODB reader giving P1691 however P0115 was a good indication towards the problems.
Thank you all for your help (in particular bigbrava)! You have been very welcoming and hope to stick around
(T) Fault Code P1691 ? paultheton1000 Punto (Mk2/2b) 10 14-03-2013 20:56
(T) P1691 Code Help - Non running Sporting BruceT Punto (Mk2/2b) 16 22-05-2011 22:27
(T) JTD engine fault light & OBD2 code "0235 UIF" davidthelodge Stilo 1 06-08-2010 00:31
obd2 code P1691, says Secure breakdown in the pdf dave Tech Talk 0 29-12-2009 00:17
(T) Fault code p1691 engine cut off from controller technixcars Punto (Mk2/2b) 0 28-09-2009 12:10
