Darryl
Cambelt Change advice please.
Hi, I have a 2006 Mk2B Punto 1.2 8v and it is due a cambelt change.
After reading Haynes manual it seems that they are saying that depending on engine number there are 2 different procedures for doing this.
1. Conventional, remove the cover and line the marks up before removing / replacing belt.
2. Using a dial gauge and proper tool to determine TDC.
I am ok with the 1st as I have done plenty of belts before and never had an issue.
If the 2nd one applies to my engine then it will be as easy going to the dealers as I do not have any special tools.
My Fiat Dealer has quoted the following prices, what do you think.
Replace Belt £125
Replace Belt and tensioners £155
Replace Belt, Tensioners and water pump £195.
One last point.
Someone told me that the 1.2 8v in my 2006 Punto is a non interference engine and that even if the belt snaps it will not trash the engine. Is that correct?
Many thanks
Replace Belt £125
One last point.
Many thanks
