Technical Mk2 punto coolant temperature sensor
hi,where exactly is the coolant sensor on a mk 2 punto 8 valve.
there are 2 connectors on the right hand side of the engine attached to inlet manifold,one has 2 wires,the other has 4 wires attached,is it 1 of these???
tony
Yeah i unscrewed it with 22mm spanner,its located near gearbox,everything i read said it was on inlet manifold,how do i test it now i have it removed??
The radiator fan is not switching on and off.the fan runs when i put power to it,and fuses are ok,so must be sensor.
But the sensor i took out is located on gearbox,and its basically a mechanical switch,put a metre acoss the 2 pins and when i pushed pin at the back of switch it made circuit,dont think its the one for the fan.
dont have a temp guage in car,the fan runs ok when i give it 12volts,will see if fan runs when i take sensor out again.
The Temperature sensor has a failsafe mechanism built in
when the cars ECU goes - Knock hello temperature please
And there is an eare silence from it the car goes and switches into limp home mode
Limp home mode does the following
A - Put the EML light on
B - The temperature guage may go off / red light come on but register cold
C - Overfuel, overfueling gives a cooler combustion = Less heat produced
D - The Radiator fan switches on
E - The car may reduce availible power, to help prevent excessive heat build up
In the haynes manual - there are all the resistances as the car warms up - using that you should be able to tell whats what if the sensor has failed
Next the Coolant temperature sensor is no where near the gearbox.... its on the inlet manifold on the cylinder head
Have a lookie here
2nd picture on the middle ish - is a green sensor on the manifold
Yes it actually is clipped in there so its part of the manifold
ziggy
removed sensor,ignition on,but the fan didnt run,i have a feeling that the screw in sensor attached to gearbox is not the one i am looking for,how would sensor on gearbox monitor coolant temperatur?
wheres ziggy?????
ok put it another way,how can i find out if the temp sensor is faulty??
they are around 50 euro so dont want to buy one unless its definately faulty,
thanks,tony
thanks,tony
This is the hard part
But basically you can measure the resistance the Temperature guage is producing
the car knows how hot or cold the temp sensor is
For example as stated in my haynes mk2
All in celcuis btw
0c = 5.37k ohms (k/o)
20c = 2.50k ohms
40c = 1.15k ohms
60C = .57k ohms
80c = .3k ohms
100c= .17k ohms
I'd stick a temperature probe in the radiator cap and run the engine checking the resistance as it warms up
problems
- Rad fan will be running as you have to disconnect the connector to read temps
- So disconnect the rad fan power cable
A temperature guage in the radiator = water has been cooled, so its hard to tell if the temperature vs readings will match
Ziggy
just looked again,my car doesnt have that sensor as shown in the diagram,
mine is 188a4000 model,will have to get some photos up to see whats going on.
188a4000 = 1.2 8v engine
that picture set is a 1.2 8v
I cant say this any clearer - YOU WILL HAVE A SENSOR THERE
unless there has been a hooligan under there before and somehow remvoed it and left a bodge job in there
What makes you believe CTS is at fault?
Ziggy
Re: Mk2b punto coolant fan
Hi, it has been said loads of times but my radiator fan is not working,
I was in slow moving traffic and the engine started to over heat.
Having a look at the car
The rad fan was seized and the 50amp maxi fuse had blown.
I have put a fan in from the scrappy (Powered up by a 12v power source and it works)
New fuse in.
The temp gauge is working ok, but when I take the wire off the sensor the fan will not kick in, I have put a wire in to short the sensor wire.
I have checked the wiring from the fan to the battery and that is fine.
I switched the 2 red relays about and still nothing (my blower fan still works)
I changed the Big black relay, one from a scrappy so not 100% sure it is a good one.
Would the temp gauge still work with a dodgy wire? any idea where the sensor wire goes? is it direct to the ecu or via the battery fuse box?
I will check the sensor wire next but any other ideas?
Adam
New fuse in.
Adam
If you remove the fan relay and bridge the larger connections the fan should run without involving the sensor, ECU or their wiring. If nothing happens you need to troubleshoot the wiring to the fan from the base of the relay and ensure you have a good earth at the Fan.
