SLOPPY1000
- Nov 28, 2010
- 8
- 2
My 2004 Punto 1.2 Active was giving me a high temperature reading with a full gage and red light. I noticed a nocking sound coming from the water tank and that was filled to maximum upon inspection. I took it in the garage today and the mechanic has replaced the radiator fan with a used one as the original kept blowing the fuse and grinding when tested. They where still working on my car when I went to collect it and they asked me to check if there was hot air coming out of heater inside the car which there wasn't. I think they then bled the car and put more water in the water tank. The problem seemed to have been sorted with warm air now coming out of the heater and a stable temp reading, well that's until I drove off. The temp went high again but by pure fluke I decided to see what happens when I turned the heater on full blast and this actually brought the reading back down to a stable temp, so my car seems drivable with the heater on full lol but I don't want to cause any avoidable damage, I'm hearing that this can be a cause of head gaskets and to me that sounds expensive.
Given the above info, does anybody know what the possible causes of the high temps and is there anything I can do to resolve it or is it another trip to the garage on Monday?
Many thanks in advance
