because the standard punto stereo's DONT have the mono/phono cables,
You'd have to steal or splice into the rear speakers and take the 2 feeds from each side
To make the phono cables up, not end of the world
You need to make sure you wire the sub up with a decent power cable and earth return while ensuring its fused correctly
1000w @ 12v = 83amp ish
So thats some sucka of a load on the already stretched power system on the punto
In winter you'd find with the lights fans heater wipers and that - when the sub woofter hits hard, the lights will keep dimming and the car may wanna die
Not only that - such huge power drains could forwell be sucking more / spiking the poor alternator
So defon consider a bigger battery upgrade AND trying to find and fit a rare 1.4 16v Punto's 100amp alternator in the same fitment style as yours!
Good luck!
Ziggy
