FIAT Auto Specialist Team
Old 20-07-2013   #1
TONY55S has donated!
Ireland
Fitting exhaust mk2 punto 8 valve
HI,i am getting a new exhaust including the flexipipe,just wondering about the bolts that connect the flexipipe,the existing ones seem to be welded on one side,so do i have to reuse these? just worried about getting the nuts off,they are so tight and if i damage the bolts do i have to get new ones rewelded,or is that necessary?
tks,tony
TONY55S is offline Reply With Quote Quote
Old 20-07-2013   #2
Trader Rating: 5
fingers99 has donated!
Re: Fitting exhaust mk2 punto 8 valve
Plus Gas or GT 85 at least a day beforehand.
Never done one on a Mk2 Punto, but the MPI Sei system has a small tack weld on the pipe itself (buzz off with an angle grinder) and a small tack on one of the clamps. This can generally be buzzed off and re-used (it's the expensive looking clamp). If you wreck it, a conventional exhaust clamp will do the job.
My guess is that the two sections are aligned on a jig before they get to the assembly line with the tacks to hold in place. Afterwards, we tend to buy only the bits we need.
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 20-07-2013   #3
Literally just changed my centre pipe with flexi on my mk2 8v and they both nuts were that tight they snapped the bolts, so I took the manifold off as its the bit with the captive bolts and just drilled them out ( took about 5 mins ) then just put some new bolts through along with a new gasket to fix them both together, easy job
Adam
UnclaimedSock is offline Reply With Quote Quote
Old 20-07-2013   #4
Oh and I only took the manifold off as it was just easier to drill them out
Adam
Old 20-07-2013   #5
Ziggy122 has donated!
Eggs Champion, Fruit Pairs Champion
They are tack welded into place
I would advise ANYBODY removing the manfiold at some point to yes replace them studs
They've had a hard life, and it means in future snapping the bolts if they are buggers means you can just literally tap the other half out
When i replace mine - i will be using new bolts and nuts
Avoid Nylon lock nuts - the heat will melt the nylon
Ziggy
!!WANTED!! 3dr Mk2 Punto Roof Bars !!WANTED!!
Meet Bumble-Bee
Ziggy122 is offline Reply With Quote Quote
Old 21-07-2013   #6
atom0007 has donated!
Try tightening them a tiny bit first, this can help break the seal and allow the penetrating fluid in. Or if you're impatient, heat them up.
Likes Ziggy122 liked this post
atom0007 is offline Reply With Quote Quote
Old 21-07-2013   #7
Im a lover of the heat kind
Lube sometimes aint enough
I cheated and left seized bolts in oil overnight really really helps
Ziggy
Meet Bumble-Bee
(T) Mk2 Punto 1.2 16 Valve Digby Punto (Mk2/2b) 2 12-10-2009 23:21
(T) punto gt stalling after dump valve fitting haribo83 Punto (Mk1) 0 10-08-2008 18:24
(G) punto mk2 8 valve forenza Punto (Mk2/2b) 1 05-02-2008 17:09
(T) punto mk2 1,2 8 valve remap? matty seasider Punto (Mk2/2b) 9 26-08-2005 13:22
bravo 1.6 16 valve vs punto (mk2) 1.2 16 valve beau Polling Station 32 23-07-2005 00:10
