Old 20-07-2013   #1
Where is the temperature sensor 8v with cam sensor
Please could someone tell me where the temp sensor is on my 2002 8v Mk2 Punto (the one with the cam sensor) I'm going mad. I've changed a gearbox on a Sei before, done a couple of guides on centos but for the love of *** I can't work out where the sensor is.
I've read the threads on here that say there is no coolant sensor, it's on the inlet manifold, yet the only part I can find to buy online is a coolant sensor.
The only candidates I can see is a two wire sensor on the right hand side of the engine as you look at the car, just near the throttle body but I'm not convinced.
Please help me out by describing what I should be looking for I'm clearly losing brain cells as I get older.
Thanks in advance.
the possibilities are endle
PhilWeaver is offline Reply With Quote Quote
Old 20-07-2013   #2
Re: Where is the temperature sensor 8v with cam sensor
This is the only two wire connector I can find but I don't think this is it is it?
Old 20-07-2013   #3
Found it!
Sorry I was having brain fade.
Old 20-07-2013   #4
Ziggy122 has donated!
Eggs Champion, Fruit Pairs Champion
Quote Originally Posted by PhilWeaver View Post
Found it!
Biggest clue would be follow the coolant lines
But glad you found it
Now you asked where it is - what points you to a failed CTS?
Ziggy
!!WANTED!! 3dr Mk2 Punto Roof Bars !!WANTED!!
Meet Bumble-Bee
Ziggy122 is offline Reply With Quote Quote
Old 21-07-2013   #5
Yeah, I'd read a post which I interpreted as meaning it wasn't actually a coolant sensor which I thought was very odd. i would probably had found it straight away if I hadn't convinced myself this was some unusual type of sensor I'd never come across!
Didn't find my fault either regrettably
(T) Crank Sensor And Cam Sensor bode Punto (Mk2/2b) 4 28-12-2011 12:23
(T) Temperature Sensor julieiito Bravo / Brava 3 15-04-2010 09:44
(T) 1.2 8v cam sensor eng going into non cam sensor si_79_uk Punto (Mk2/2b) 1 04-01-2008 14:28
(G) Temperature sensor Mabby Punto (Mk2/2b) 2 04-08-2006 18:23
