Old 06-07-2013   #1
Busy rebuilding pand'a
oldhammer's Avatar
oldhammer has donated!
16v oil leak.
Hi all,
I'm a bit lost with this one so any advice is much appreciated.
I've just bought a 16v sporting for the mrs,
Its running well but there's a mystery oil leak.
When its parked stationery engine running reved/or ticking over there's not one sighn of an oil leak but after 15mins on a run its stinking of oil fumes in the car
Oils dripping down on too the exhaust.
Sump and gasket is new.
Head and cam gaskets are new.
I'm lost with what else to try.
Any ideas.
Before I get the swan Vesta out on the fecking thing lol.
oldhammer is offline Reply With Quote Quote
Old 06-07-2013   #2
Azzam has donated!
Re: 16v oil leak.
i remember on my old 16v always has a cam cover leak...... got sick of it so i bought another gasket and used loctite instant gasket sealer and the oil leaks went away.
cleaned the surfaces put a bead of sealer on the cylinder head, place the gasket on the top.... put more sealant on the gasket and bolt on the cam cover
Thanks oldhammer thanked for this post
Subtle but in your face.
Azzam is offline Reply With Quote Quote
Old 06-07-2013   #3
Brain stopped play
homeward's Avatar
Trader Rating: 1
homeward is part of the official FF Events Team :)
homeward has donated!
Question Re: 16v oil leak.
I wonder if it's something as simple as a bust breather hose...? They seem to fail pretty regularly....
1990 Panda 750L Formula '90: Pippin (26,131 miles; 47.18 mpg)
2009 Panda 1.2 Eleganza Dualogic: Pandora (55,670 miles; 47.87 mpg)
2002 Punto 1.2 16v ELX Speedgear: Priscilla (100,465 miles; 41.30 mpg)
homeward is offline Reply With Quote Quote
Old 06-07-2013   #4
oldhammer's Avatar
Thumbs up Re: 16v oil leak.
Thanks for the reply .
The car as just had a top end rebuild.
Gaskets are new.
There's no leak from the cam cover/extension.
Its further down this is the puzzling part as to where I've spent hours looking for the leak
The oil is been blown just above the steering rack /middle of car and then its
Seaping on to the exhaust.
Old 06-07-2013   #5
oldhammer's Avatar
Re: 16v oil leak.
Icarnt see a breather hose.
Any ideas where to. Look for it.
Thanks for the suggestion on that.
Old 06-07-2013   #6
Azzam has donated!
Re: 16v oil leak.
you sure its engine oil? not a corroded brake pipe?
Old 06-07-2013   #7
oldhammer's Avatar
Re: 16v oil leak.
Yes its deffo engine oil mate.
The brake fluid is full. No leaks there.
Old 06-07-2013   #8
Brain stopped play
homeward's Avatar
Trader Rating: 1
Red face Re: 16v oil leak.
Quote Originally Posted by oldhammer View Post
It doesn't sound like it is now... -- but have a look towards the end of this post, in my Members Motors thread: it's the hose that comes out of the airbox, in the middle, on the right-hand side (as you look towards the back of the car...). They tend to split, and can spew oil just about anywhere....
Old 06-07-2013   #9
oldhammer's Avatar
Re: 16v oil leak.
Thanks for the link and the info.
I've took the air box back off. Breather pipe looks fine.
Top end of the engine is dry/no oil.
Under the inlet manifold is soaked.
Leak looks to be coming from the block just past the alternator bracket.
I've also checked the oil level, and its high/over filled..
So I'm now wondering if its why it blowing oil out... but as to where I'm lost.
Around the dipstick is dry.
Old 06-07-2013   #10
atom0007 has donated!
Re: 16v oil leak.
Drain a bit off?
atom0007 is offline Reply With Quote Quote
Old 06-07-2013   #11
Ziggy122 has donated!
Eggs Champion, Fruit Pairs Champion
Re: 16v oil leak.
i'd crack the oil filter off then - drain the oil filters oil out
Refit it and see if this cures the issue
Ziggy
!!WANTED!! 3dr Mk2 Punto Roof Bars !!WANTED!!
Meet Bumble-Bee
Ziggy122 is offline Reply With Quote Quote
Old 07-07-2013   #12
oldhammer's Avatar
Re: 16v oil leak.
Thanks Ziggy.
I've dumped some of the oil.
Cleaned everything off and took it for a 30 mile run.
Got back and there's oil all over the bulk head/top of steering rack.
Its not as bad as before but its still dripping on to the exhaust, /fire hazard
I'm now thinking inlet manifold gasket,
I will give that a try and see what happens, I'm so fed up with this car now,
I'm close to putting it on the scales and weighing it in..
Old 08-07-2013   #13
Azzam has donated!
Re: 16v oil leak.
probably leaking from your headgasket, oil port on the hg probably leaky? just guessing though. dont scrap it...... just needs better diagnosing with a 2 post lift
Old 08-07-2013   #14
oldhammer's Avatar
Re: 16v oil leak.
Quote Originally Posted by Azzam View Post
Thanks for the reply.
Head gasket is new and the heads been skimmed.
I bought the car as a none runner /cam belt fail-bent valves etc
I've took the inlet manifold back off -that wasn't it. As ioriginaly thought..
Had the car over the pit ..still carnt find the leak..
It don't leak oil on standstill/only happens going down hill from steep incline.
The leak as slowed down now.. but its still dripping on to exhaust.
I might throw some millers stop-leak or the likes and see what happens..
Dunno what else to try next,
Old 08-07-2013   #15
Re: 16v oil leak.
Wanna pack your heart with fat?
Its the same thing with these ""magic sealers""
They just clog up the water and oil ways to seal a leak, but at what cost?
restricted flow?
anyway
Spent 10mins looking on the pictures of a 1.4 16v which is almost identical to the 1.2 16v
Here
Only things that can leak are
the oil dipstick
The Sump gasket
the rare case a HG leaking down, usually HG only leak in, rare they leak out?
unless there is a crack somewhere and its allowing oil to escape
maybe an vacuum guage test will comfirm things?
Ziggy
Meet Bumble-Bee
(T) punto mk2 1,4 16V Drainage bolt oil leak chris lar1968 Punto (Mk2/2b) 6 04-05-2012 22:46
(T) Oil leak 16v Jonnybobs Punto (Mk2/2b) 2 02-03-2012 20:08
(T) Seicento Oil leak & seperate Water Leak from Head?!?! Please help. Hamilton Cinquecento / Seicento 22 21-10-2010 12:45
1.2 16v major oil leak Alan Mac Tech Talk 1 23-08-2010 11:47
(T) Oil leak, tappets, now engine whine and oil burn Extintor Punto (Mk2/2b) 5 15-11-2005 11:15
