FIAT Auto Specialist Team
Old 14-06-2005   #1
engine management light flashes ?
Hi all ,
New to this forum but i have been having a good read recently about the big ecu problem puntos have been hit by..
I had to replace mine and now my car runs fine BUT
my engine manangement light flashes constantly.
I put this ECU in this morning myself and it has read my code and started fine.
The ecu was virgin and uncoded.
Can anyone enlighten me as to why this light is flashing?
Any suggestions ?
Will this light stop flashing after the car has got used to the chip or something ?
jonny2005 is offline Reply With Quote Quote
Old 14-06-2005   #2
is one with the dark side
Citizen Smith's Avatar
Trader Rating: 1
Citizen Smith has donated!
Re: engine management light flashes ?
Quote Originally Posted by jonny2005
Hi all ,
Any suggestions ?
Is it mark 2 punto, if so does the engine light STAY on, or does it Flash on/off ?
VW Golf GTi
"power is nothing without control"
Citizen Smith is offline Reply With Quote Quote
Old 15-06-2005   #3
Forum Moderator
T14086's Avatar
T14086 has donated!
Let it heat up(fan cuts in)& briefly rev it to 6000rpm then let idle....repeat 3 times & light will go out.I'm assuming its a new style(not Mk1 punto),basically its phonic wheel learning.
Likes dave, MadMan0 liked this post
Old 15-06-2005   #4
Yeah sorry guys for late post.. it is mk2 2002 1.2 active
And flashes not stays on !
I will try that mate cheers
Old 15-06-2005   #5
hi fellas i did what you said about the revs and thanks all sorted
Hope this ecu doesnt pack in
Old 15-06-2005   #6
Forum Moderator
T14086's Avatar
T14086 has donated!
Sure it will be fine.................for a while
Old 17-05-2011   #7
Quote Originally Posted by T14086 View Post
Tried the Phonic with mine and it wont go to 6000, stops at 5000. Any ideas? Its 1.3 multijet diesel punto grande
Libertine is offline Reply With Quote Quote
Old 17-05-2011   #8
I'm surprised a diesel can go that fast. !!!
DaveMcT is offline Reply With Quote Quote
Old 17-05-2011   #9
Ziggy122 has donated!
Eggs Champion, Fruit Pairs Champion
Quote Originally Posted by Libertine View Post
diesel use a Much Highter Compression then a petrol engine
So to prevent them blowing the heads off - they dont rev as hard
Diesels dont need to rev anyway - there all torque
plus with a Turbo on there - it'll go when you ask
the 16v Petrols can do 7k Redlined
8v Petrols About 6.25 / 6.5k redlined
Diesels are about 5k max
Ziggy
!!WANTED!! 3dr Mk2 Punto Roof Bars !!WANTED!!
Meet Bumble-Bee
Ziggy122 is offline Reply With Quote Quote
Old 17-05-2011   #10
Most diesels top out at 4500 and are pretty rubbish between 3,500 and 4000. Apart from the heavy moving parts diesel fuel wont burn fast enough to let it rev higher which is why they belch smoke when thrashed at high revs. Most power is between 1500 and 3,500 with a steep drop off either side.
Old 17-05-2011   #11
Phonic wheel learn only applies to petrol models.
If your engine warning lamp is flashing on an mJet, and its a new ECU, you need to go to the Dealer/a specialist who can programme-in the injector codes.
D4nny8oy is offline Reply With Quote Quote
Old 18-05-2011   #12
Quote Originally Posted by D4nny8oy View Post
Nice one DannyBoy
Old 20-05-2011   #13
Forum Moderator
T14086's Avatar
T14086 has donated!
At a cost of 55-80
Old 21-05-2011   #14
Mk1 Punto Owner - 51 Mpg
MadMan0's Avatar
MadMan0 has donated!
Does it have to be 6000 rpm and does the engine have to be at 90'C or can it just be high rpm and 60'c?
2004 mk2/b punto
MadMan0 is offline Reply With Quote Quote
Old 21-05-2011   #15
MadMan0's Avatar
http://www.x431ltd.co.uk/website/Lea...20onwards.html
Link above states over 5000 rpm, i had to ask as our mk2/b 1.2 8v petrol wouldn't go over 5k rpm,
sorted now though Reved to 5k - limit in this case, let it idle - re started the car, then i would go over 6k rpm? not sure how this helped but it did
then did the phonic wheel learning jobby, and the light has stopped flashing
Cheers all
(T) Uno 999 FIRE ie erratic idle on warm up (Bosch SPI) darren_hill Uno 12 07-11-2016 21:45
(T) engine management system baz10 Punto (Mk2/2b) 3 15-01-2009 08:29
(T) engine swaps HP Cinquecento / Seicento 0 31-12-2004 00:17
(T) Engine Light dabravokid Bravo / Brava 1 03-12-2004 22:19
(T) New engine, old problem bocai Punto (Mk2/2b) 5 03-12-2004 09:25
