Technical Misfire/Judder at 2k/2.5k Revs P1135
glennmr2
have had this niggling problem for sometime now and just cant seem to get to the bottom of it,
Basically The car has been misfiring normally around 2k 2.5k revs,
I had it scanned and it came back with P1135 which is lamba sensor before cat, so replaced that and had the code cleared but still misfiring, then I replaced all spark plugs, leads, and coil packs, result = still a misfire,
I got myself a scanner and scanned again and it still showing P1135, I have cleared it a few times and it keeps coming back,
anyway today what I decided to do is swap the 2 lamba sensors over (post and pre cat), erased all codes, now I still have the misfire when I'm driving but am no longer getting the code back any more, so I'm guessing this has ruled out the lamba has a fault ?
not sure what to check next, any idea guys ??
also I have noticed the spark plugs are very white as if its running way to lean, which would explain the misfire but haven't got a clue what my next step is other then take it to a garage
thanks in advance, all help very much appreciated
