Old 06-06-2013   #1
Brake fluid spraying out when I press brake pedal
From front far side brake. I thought a pipe was worn through as it felt a bit worn on one side, so I taped it up with speed tape to test this theory, but the fluid seems to spraying from somewhere else. There's no standing leak, and it only happens when I press the pedal. Unfortunately, I'm on my own so I can't ask someone to have a look while I pump it.
It happened a minute or so after braking heavily at a roundabout, so I suspect that has forced something.
Any ideas folks before I get a chance to have a proper look tomorrow?
Firthy is offline Reply With Quote Quote
Old 06-06-2013   #2
Ziggy122 has donated!
Eggs Champion, Fruit Pairs Champion
Re: Brake fluid spraying out when I press brake pedal
3 things
1 - caution to bodywork as brake fluid will physically remove paint
2 - If its spraying, eye protection, you dont want it in your eyes
3 - if you get sprayed, rinse off well with water, Brake fluid is extremely poisonous to the body
Its time to have the car in the air - wheels off and investigate where damp patches are
Brake fluid squirting = Air entering
Air entering = less braking force been applied + Spongy pedal
Spongy pedal = Asking for an accident / crash as you cant stop
STOP DRIVING AND SORT IT!
I suspect a worn flexi, as there prone to aging and failing over years
Locate damp patches - clean up, and test, if new fluid appears its near by
Metal pipes can also rot, a small pin prick can cause a leak and cause the above problem
Borrow a friend, neighbour, family member to just press the pedal if you dare while observing
ziggy
Likes Brendan W liked this post
!!WANTED!! 3dr Mk2 Punto Roof Bars !!WANTED!!
Meet Bumble-Bee
Ziggy122 is offline Reply With Quote Quote
Old 06-06-2013   #3
Burkina Faso (Upper Volta)
cant add anything much but these puntos like all cars can go through brakes hoses due to age,rubbing,bad routing
do not drive it anywhere until sorted as the fluid in the master cylinder will soon be exhausted
s and b is offline Reply With Quote Quote
Old 06-06-2013   #4
Thanks for the incredibly quick responses!
Obviously, I don't intend to drive it anywhere until it's properly sorted. Luckily I was parked outside my house when it actually went.
I did clean everything up before I tested it again, but the spray is pretty wide so it was extremely difficult to tell where it had come from. I'll get it up on some ramps tomorrow and do a proper inspection of all the pipes and hoses. Hopefully it's something as simple as that. I'll let you know how I get on...
Cheers.
Old 06-06-2013   #5
Look on the brake master cylinder cover for what dot rating you need FOR BRAKE FLUID if doing job it yourself and take a photo of how the hose goes on the strut because it looks wrong when its right if you get me
The little metal pin holding the hose in the strut fasteners break so substitute it for a small tie clip if it does and use a little fairy liquid to get the grommit round the hose in and out of the fixing
Old 06-06-2013   #6
The optimist in me says the wide spray could be a good sign as it would indicate that the leak is a tiny hole in a pipe somewhere. We'll see.
Old 06-06-2013   #7
Quote Originally Posted by s and b View Post
Dot 4. I've had an unopened bottle of it in my tool cupboard for a while now, just in case.
Cheers for the advice.
Old 06-06-2013   #8
Quote Originally Posted by Firthy View Post
In thoery the Wide spray = tiny hole + Lots of pressure
Thats how injectors work to a degree
The Kitchen paper test should help
Stick a piece as big as possible over the pipe work - press brake pedal - look at paper
is it wet there?
How? Localised? Drained down
The results will tell you where to move too
Ziggy
Meet Bumble-Bee
Old 06-06-2013   #9
atom0007 has donated!
Hope it's the flexi pipes, easier to fix than rotten steel brake pipes. If you redo them, you can either buy from dealer, or make new with copper or copper nickel pipe.
Other places are unions and calliper piston seal, although these are probably not as likely.
Thanks Firthy thanked for this post
Likes Firthy liked this post
atom0007 is offline Reply With Quote Quote
Old 06-06-2013   #10
dave's Avatar
Trader Rating: 10
dave has donated!
Quote Originally Posted by Ziggy122 View Post
ziggy
hurts like hell but makes @ben laugh
Likes ben, Firthy, atom0007 liked this post
THIS IS WHY TORIES CANT CLAIM HINDSIGHT! https://www.youtube.com/watch?v=bQDPQ8bz7cU
Old 06-06-2013   #11
Trader Rating: 5
fingers99 has donated!
Just don't get so optimistic that you drive the car!
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 06-06-2013   #12
is it wet there?
Ziggy
That was my thinking.
I'll probably follow those steps exactly in the morning. At least it's the weather for it! Thanks ziggy.
Old 06-06-2013   #13
Quote Originally Posted by fingers99 View Post
No chance of that. I've got kids, and I'm not really into mowing down pedestrians.
Old 07-06-2013   #14
Right, I've had a proper look this morning and it is the flexi-hose I suspected. It's been rubbing on a bracket in the wheel arch. Ordered a replacement one at my local auto factors and I'll be picking it up later on today. Just under 9 quid! I'll post photos when I actually change it, either tonight or tomorrow, just for future reference. Cheers gents.
Old 07-06-2013   #15
Ensure you refit correctly to prevent the new brake pipe rubbing through
There should be a little bracket to hold it securly, ensure you do this
I had a brand new one, without the bracket - rub against the wheel again and MOT fail it
Ziggy
Meet Bumble-Bee
(T) I can't press brake pedal traktor90 Uno 4 12-02-2011 23:11
(T) press brake pedal headlights come on jane cinqu Cinquecento / Seicento 7 11-11-2009 19:34
(T) My Punto needs Brake Fluid, isit a certain one i must get or any brake fluid will do? keepinitcriss Punto (Mk2/2b) 5 02-04-2007 18:30
(T) Indicator stopping (flashing) when i press the brake pedal Nath86 Punto (Mk1) 5 11-01-2007 05:49
