crazyfrenchbird
Hi all, I am a newbie here but have been using the Forum for past few months since I started having problems with my 1.2 16v active sport and after doing a lot of work to it I am still looking for a solution to some problems.
Bought the car in Sept 2012 with 103K on the clock (1 owner from new) and the first problem was overheating. After changing cooling fan, temperature sensor and thermostat, the car is now running fine at the right temp (93degrees all the time and the engine gets warm extremely quickly still though)
2nd problem, after a couple of months the engine management light came on and RAC were called out and ECM error code came up P1135 meaning Third Piston Deactivation Control Circuit - RAC bloke cleared the error with his code reader and told me to replace the front Lambda sensor and this should sort it out. I couldnt afford to do it straight away and the light came on again a couple of months later but disappeared on its own 4 days later!! I have now finally done the sensor last week, and 4 days later the light has come on again and the engine starting running on 3 cylinders. RAC came out again and diagnose one of the HT leads had broken down (£45 for a new set mind you!!!) so I changed all the leads and he cleared all the errors (P1135 again and P0130 lambda sensor again!!) and the car was running like a dream with proper accelaretion and fuel comsumption was so much better.
Unfortunately a couple of days ago the engine management light has come again and the car has lost it va-va-voom and running lumpy again and is now being slugish especially going uphill and not starting very well whether its hot or not. I havent called the RAC yet to clear the codes or find out what code it is this time (although I have a funny suspicion it will be the same codes!! (RAC will be starting to hate me now I have called them 4 times so far this year as you can imagine!!). I am a local delivery driver for a restaurant working 3 hours a night so stop/start/stop/starting all the time so I know its affecting my started motor and probably my alternator (which I have been told is on its way out cos the bearings are getting louder and louder). I am now at a total loss as to what else I need to check or replace or repair. Although I am a girl I have done most of the repairs myself and source all my parts on eBay to keep costs down. I have spent alot of my car so far and dont wanna lose it but this is really getting to me now so anyone who has any idea what else needs doing to finally keep clear of this poxy engine management light coming on and getting my engine to run smoothly and powerful again, your help would be much appreciated.
If you need any more details dont hesitate to ask questions and I will answer them promptly
Thanks all
CFB
Thanks all
CFB
