Wow! Sorry to dig up an OLD thread, but this one is EXACTLY the issue I'm having
I haven't been on here for years, but my son started to drive in the last couple of years and is driving a Punto 1.2 8v
Recently he contacted me to say his car was not running right at all while on a journey. Went through a few things over the phone, and thought it might have been coil related, then checked oil and that was low, so topped up the oil also, but abandoned the journey and almost struggled home, except the car stopped when he was close to home and he was afraid to try start again in case he did any damage.
Car was towed back, and has been parked up for a few weeks.
The other day, I charged the battery and tried to start it and it was really badly misfiring and would not even stay running. I disconnected all the HT leads from the coil packs, and pushed them back on, started the car again and although still a bad misfire, it wasn't as bad, and stayed running this time.
I proceeded to remove the HT leads one by one from the 2 coil packs, and found that the front port on the rear pack (closest to the bulkhead) was not giving much of a spark when turning the ignition. All other ports seemed to fire ok. Also, the check engine light was lit on the dashboard.
So as one of the ports on the pack was sparking, I assumed this was not an ECU issue, and the pack was damaged. We took an old coil pack from an old Punto he had with same engine, but the car is still misfiring and when I did the HT lead test again, it was the very same port which is still not sparking! Only thing is, the engine light is now no longer showing on the dash.
I have attched a picture of the frame, showing the firing order, and it seems to be the port going to cylinder Number 1 which is the one with problems. Is it possible that this coil pack is also gone on the same port which would seem hugely coincidental, or am I totally missing something here?
