Thread Tools
Old 06-04-2013   #1
Punto 1.2 8v
BradThomas's Avatar
BradThomas has donated!
Punto Water Noise When Revving/Starting? : Video
This is what it sounds like...
the video quality isnt the best as it was recorded on my iphone -_-
you can hear the noise when i rev the car, may need to turn your volume up...
what is this? also makes this noise when im driving
Brad
BradThomas is offline Reply With Quote Quote
Old 06-04-2013   #2
Banned
Trader Rating: 1
benny279 has donated!
Re: Punto Water Noise When Revving/Starting? : Video
You have air trapped in the cooling system, you'll need to bleed the system to get rid of this noise.
Follow @dave's guide:
https://www.fiatforum.com/punto-guid...l-engines.html
Just bare in mind it may take more than one attempt, as the MK2's cooling system is a pig of a system to bleed
Good luck!
Benny
benny279 is offline Reply With Quote Quote
Old 06-04-2013   #3
Punto 1.2 8v
BradThomas's Avatar
Cheers Benny,
does this affect the car, like if i left it alone would it do anything?
but yes i will try that guide
cheers
Brad
Old 06-04-2013   #4
Banned
Trader Rating: 1
Quote Originally Posted by BradThomas View Post
Cheers Benny,
cheers
As long as the air does not affect the engine's cooling system if it does it will cause the engine to overheat, if it was me I'd bleed it when you can. Although you can probably ignore it for a little while, you'll just have an annoying noise when revving/starting
Benny
Old 07-04-2013   #5
Ziggy122 has donated!
Eggs Champion, Fruit Pairs Champion
Bleed bleed bleed
Air pockets = Hot spots
If you have an air pocket sitting in the head - oh dear - its not usually good news
Now
Air in - means water out usually
or if its had a coolant change/removal/refill it'll just be airlocked
If there is a leak - the air is replacing the lost water, find the leak and report back after bleeding it well and truly
they can be a pig todo - i find having the nose up slightly can help loads
ziggy
!!WANTED!! 3dr Mk2 Punto Roof Bars !!WANTED!!
Meet Bumble-Bee
Ziggy122 is offline Reply With Quote Quote
Old 07-04-2013   #6
Punto 1.2 8v
BradThomas's Avatar
I have sorted this, was outside and just thought I would see what the level was at, I undone the filler cap and the water started filling up as its pressurised (I think) it was full so I put the cap back on started the car and no water noise, air must have been trapped in the actual filler bottle I don't know :L fixed it anyhow
Brad
Thread Tools
(T) Punto mk2 1.2 8v Petrol Smell And Water Noise drm08 Punto (Mk2/2b) 8 27-03-2013 17:14
(G) Gurgling noise when revving... benny279 Punto (Mk2/2b) 4 13-03-2013 20:33
(T) Cinq SX 97 starting problems and over revving ooar parsley Cinquecento / Seicento 8 01-06-2010 21:48
(T) Non-starting MK1 Punto + Oil & Water Mixed! baxter82fiat Punto (Mk1) 4 26-01-2009 13:54
(T) Engine starting difficulties and revving up and down at idle roombacurious Punto (Mk2/2b) 1 26-09-2007 20:08
