Thread Tools
Old 30-03-2013   #1
Punto 1.2 8v
BradThomas's Avatar
BradThomas has donated!
Thumbs down Punto MK2 Front Wiper Problems
Basically when i have the wipers on a certain setting it sticks at the top then when it goes to return to its normal place it stays half way up the windscreen.
But when its on an other mode they work perfectly normal and do not stop, so currently i have to manually put them back to the starting position by flicking the wiper settings to the top one they quickly put it back down when there in the right place if anyone understands :/
would love to know what this could be or what i could do to try and find out?
Brad
BradThomas is offline Reply With Quote Quote
Old 30-03-2013   #2
Ziggy122 has donated!
Eggs Champion, Fruit Pairs Champion
Re: Punto MK2 Front Wiper Problems
So the wipers are struggling to park in the correct position
But on others its sitting fine?
we've had alot of crap weather recently, with blocked scuttle pannel drain holes, your motor / rotors could be affected by water?
Ziggy
!!WANTED!! 3dr Mk2 Punto Roof Bars !!WANTED!!
Meet Bumble-Bee
Ziggy122 is offline Reply With Quote Quote
Old 30-03-2013   #3
Punto 1.2 8v
BradThomas's Avatar
They stick when they get to the top of the windscreen then struggle to come back down just on the one setting, been like this since I brought the car
Brad
Old 31-03-2013   #4
Burkina Faso (Upper Volta)
bonnet shut
wipers off screen
what happens now?
s and b is offline Reply With Quote Quote
Old 31-03-2013   #5
Goes to the top, then on it's way back down it jerks across the screen with a buzzing noise from under the dash?- lack of grease on the motor contacts inside (fixed under a Service Bulletin when reported in the first 3 years). You have to remove the top plate on the motor, remove what's left of the original grease and re-apply with some fresh stuff over the tracks and contacts.
D4nny8oy is offline Reply With Quote Quote
Old 01-04-2013   #6
Punto 1.2 8v
BradThomas's Avatar
Follwed a guide on how to clean the contacts and it has fixed the juddering but now they don't go back to the starting position they stop, then go down then go back up could this be the relay? No buzzing from dash
Brad
Old 01-04-2013   #7
If they're parking in the wrong place on the screen, and it's not a mk2b linkage on a mk2, it'll be the alignment of the linkage to the motor.
With the wipers parked, the crank arm on the motor should be exactly parallel with the linkage (and access to the fixing nut is difficult). If it's not, it'll cause what you're describing- where the wiper sweep arc is correct from end to end, but the parking position is wrong, so you'll have to remove the assembly, undo the nut, and re-align it all (without turning the motor).
Thread Tools
(T) Front wiper linkages mk2 Punto hornyas Punto (Mk2/2b) 26 14-02-2011 17:59
(T) Front Wiper Problems davethehorse Bravo / Brava 3 30-04-2010 08:56
(T) front wiper problems dazzer01 Cinquecento / Seicento 5 08-04-2010 19:50
