- Mar 14, 2013
- 13
- 56
Intermittent starting problem FIAT PUNTO 1.2, 2004, 60000 miles regularly serviced
Have read through lots of threads on starting problems but nothing quite matches my situation and I’m hoping that my symptoms will suggest some obvious things to check before I take it back to the garage - which is likely to prove expensive.
Car can start/run fine for weeks then when I come to start up, either from cold or even after stopping for 10 minutes, turn the key and just just get a single click and/or ticking sound, generally engine doesn’t turn over at all. Clock reading (time clock not speedo) goes to zero. Will then sometimes start OK. Has happened in cold/warm/wet, weather doesn’t seem to make a difference.
Car will always start easily with a small push. Also has started on one occasion when hand break let off whilst in gear and car rolled forward about a foot and then engine turned over fine.
Last week EOMD light came on during a long run in daylight ie no lights being used (car went into limp home mode). Stayed on despite several stops but had gone off by the time we got back to our local garage. Diagnostics showed ‘low voltage to battery’ in the memory.
The roads round here are not great, very uneven and lots of potholes so the car does get bounced about a bit, don't know if that is significant.
Don’t know if these symptoms are all due to the same thing but would appreciate any thoughts.
