FIAT Auto Specialist Team
Thread Tools
Old 09-03-2013   #1
Ireland
Thermostat Change
I'm looking to change out the Thermostat on my 2000 1.2 8v MK2 Punto.
I have the part and tools here and ready to go but i cant find it anywhere, i've searched and tried to find guides but cant find anything.
If anyone could point me in the right direction that would be great or have a picture of where its located that would be even better.
Cheers for any info.
ph0rce is offline Reply With Quote Quote
Old 09-03-2013   #2
Re: Thermostat Change
Right hand side on the engine it's sticking out of the head with a pipe attached to it, remove the air filter for better access. Ps held on by two 10mm bolts
Likes ph0rce liked this post
Mattbcon is offline Reply With Quote Quote
Old 09-03-2013   #3
Ireland
Cheers for that.
I'm looking there and have the box off just cant see the thing, i have the replacement in my hand so i know what it looks like.
Any pics??? Or Anything like that.
I'll go get my glasses on as its probably right in front of me
Old 09-03-2013   #4
Slovenia
On right side of the engine - looking towards the back of the car, below valve cover you will see about 1 inch pipe leading from the engine to the top of the the radiator. Wel,l this pipe is conected to the engine by the thermostat. You can't see metal pipe of the thermostat because it is stucked into the hose.
For pictures use google image...
http://www.google.si/search?q=punto+thermostat&oe=utf-8&aq=t&rls=org.mozilla:sl:official&client=firefox-a&channel=np&um=1&ie=UTF-8&hl=sl&tbm=isch&source=og&sa=N&tab=wi&ei=MCk7Ubf2LcrL4ATvvYCwAw&biw=1366&bih=664&sei=Myk7UcC-HYfE4gTi2YHgAg#imgrc=_
why are you changing it?
Uno mk2 1.0 fire, Punto mk2 1.4 16v, Bravo mk2 Startjet Dynamic 1.4 16v
Karletto is offline Reply With Quote Quote
Old 09-03-2013   #5
Ireland
Thanks for the help folks, just changed it out there.
Was having problems with the engine temp, was never showing any rise in temp on the dash, so i was guessing that my engine was always running cold due to stuck open thermostat, lot of knocking going on, anyway replaced it there and shes running smooth again.
Happy days
Old 09-03-2013   #6
Speed Reader of the Year!
Most Easterly Pandas's Avatar
Trader Rating: 2
Most Easterly Pandas has donated!
It's under the coil packs
Most Easterly Pandas is offline Reply With Quote Quote
Old 09-03-2013   #7
Ireland
There she is ready for the bin
New one now in
Old 09-03-2013   #8
Azzam has donated!
you wouldn't believe how much mpg you get more once you change it! mine was kapput was only going upto 1/4 high..... getting around 33mpg changed it now i get 42mpg!
Subtle but in your face.
Azzam is offline Reply With Quote Quote
Old 09-03-2013   #9
Ziggy122 has donated!
Eggs Champion, Fruit Pairs Champion
Make sure you run it upto temperature to sensure no leaks under full pressure and running
and that you bleed all of the lovely lovely air out
But yes - a good working stat will save you bucket loads in the long run
The ecu will always see the engine as been cold - bung **** tones of fuel in to try and warm it up
lazy stat = Nvere warms up = more fuel
See where im heading?
Good! Enjoy the task its simple and easy
Ziggy
!!WANTED!! 3dr Mk2 Punto Roof Bars !!WANTED!!
Meet Bumble-Bee
Ziggy122 is offline Reply With Quote Quote
Old 10-03-2013   #10
Ireland
Quote Originally Posted by Ziggy122 View Post
Ziggy
Right i can hear lots of water splashing about when i start the car, i didnt bleed the the coolant, i can see the valve on the rad its just like a thumb screw but cant see the second one, ive been told to look at the pipe on passenger side, i can see kinda like 3 pipes in a T shape and theres a kinda valve on it with a normal flathead screw on it is this it???
And when bleeding do i need to keep topping up the tank until water comes through or should it just come out with out the need of topping up say like a radiator in the home.
I read the guide but it doesnt make sense to me
Sorry but im a noob and havent a clue, but i do try.
Old 10-03-2013   #11
Ireland
Its cool i found it
Car is driving me mental
Changed the plugs, leads
Changed oil, oil filter, air filter.
Checked coil packs by disconnecting them one at a time and car starts fine on both.
Changed out o2 sensor and check voltage 0.1-0.2 - 0.6-0.7
Changed the map sensor
Changed thermostat.
Had timing belt, tensioner and water pump done.
And the car is still knocking and jumping really bad, and still getting only about 26mpg
The only thing left i can think of is the head gasket is on the way out
Old 10-03-2013   #12
Slovenia
If you changed all that, i presume it also took you some time to do it.
Signs of failed HG would be noticable in a matter of one week and in two weeks or less it would already be "game over" - temperature in red zone, bad missfire, white smoke, bubbles in the coolant with engine running etc.
Thread Tools
(T) How long to change a thermostat?? Flatwhite Bravo / Brava 1 08-01-2013 22:05
(T) thermostat change ROWENA Stilo 6 10-02-2009 09:13
(T) About to change a Thermostat on Brava Greame Smithy Bravo / Brava 7 10-11-2008 09:13
(T) Thermostat change calvjones Panda 0 01-10-2008 15:50
(G) Thermostat Change Problem barachello2000 Punto (Mk2/2b) 12 07-12-2007 21:44
