hello!
i got a problem with my punto hgt '00 mk2 cooling fan
when my engine is running, after 10 seconds the fan starts spinning full-speed, it doesn't matter if the engine is cold or warm. but it does not run if only the ignition is on.
- tested temp-sensor in FES: shows normal temperature
- swapped relais against others
- tested relais with FES: everythings ok
i also got a fault code:
P1531 - air con relais or circuit faulty (i can't delete this error)
but my air con is working
can anyone help me please?
thanks and greets from switzerland
