Old 20-01-2013   #1
now issues with spark plug holes
after a supprisingly successful head gasket change i now have issues fitting the spark plugs
no1 and no 2 went in no probs with a little grease but im having issues with 3 and 4
no 4 was only in half way and quite loose when i removed which was probably a contributing factor to the poor running in the first place.
previous owner has obviously done some work on it as he left cam cover loose and no 4 plug loose and thus oil was leaking down and into the plug hole! muppet!
any ideas of how i can get them in without buggering up the threads completely?
ive tried with a chaser but it appears the socket is too thick to go into plug hole
maybe thinking a hardned 14mm bolt and lube to clean threads? or possibly some copper grease on threads?
issue is they feel very tight at about 2 3rds of the way in and i dont want to force in due to the head obviously being ally and dont want it cracked or f**ked after having it skimmed and re fitting it
any ideas greatly appriciated
juicedjay is offline Reply With Quote Quote
Old 20-01-2013   #2
Trader Rating: 5
fingers99 has donated!
Re: now issues with spark plug holes
Very difficult to know without looking/feeling it.
You really, really, really, should have checked before you put the head back on. My best course of action would be to remove the head.
If you insist on not doing that, then you can make a chaser by bashing the insides out of an old spark plug, cutting 4 slots in it (hacksaw), filing down any obvious sticky out bits (needle file) and filling with grease.
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 20-01-2013   #3
Ziggy122 has donated!
Eggs Champion, Fruit Pairs Champion
i'd be worried if using a chaser thread cleaner dropping swarf into the engine
Ziggy
!!WANTED!! 3dr Mk2 Punto Roof Bars !!WANTED!!
Meet Bumble-Bee
Ziggy122 is offline Reply With Quote Quote
Old 20-01-2013   #4
Trader Rating: 5
Yep.
That's what the grease is for, but you'd not expect it to be 100% effective.
M12 fund 20
Old 20-01-2013   #5
i'd be tempted to prevent swarming the engine - just take the head off - run a tap and die through it instead
But thats alot of work i know
Atleast tho - while the head is off - you can easily insert the new plugs
Ziggy
Meet Bumble-Bee
Old 20-01-2013   #6
Trader Rating: 5
Tap will probably be too sharp, possibility of more damage.
But, yeah, head removal is safest bet.
If the threads are fubar, they can be recovered by helicoil or similar insert.
M12 fund 20
Old 21-01-2013   #7
Yes makes sense ideally i didnt want to have take head off again but ive taken it off anyway to be on safe side, ive ordered a tool to re thread and put inserts in ( not helicoil ) hopefully this will work if not ill just drill, tap and use a helicoil as i have in the past for other ally head threads.
Pain in the back side but at least once all bk together should be good to go, where as if i leave swarf in eventually no doubt cause damage to the bores etc
cheers guys
Old 21-01-2013   #8
Thats the issue - the bores could forwell be swarf scored and compression issues and then running issues - new engine or a rebore etc etc
4hours to remove head isn't that bad really to play it safe
ziggy
Meet Bumble-Bee
what spark plugs, what spark plug gap dave Punto (Mk2/2b) 4 21-07-2016 11:23
(G) Spark plug georgee Bravo 15 09-01-2013 09:27
(T) oil in plug holes ROWENA Stilo 2 19-12-2008 14:38
(T) Compression test on 1.2 16v .. deep spark holes kritip Punto (Mk2/2b) 2 13-06-2007 09:34
Butt-Plug? Ah! Spark-Plug? (worksafe) MrDerv Leisure Lounge 6 05-07-2004 04:40
