Thread Tools
Old 20-01-2013   #1
Banned
Trader Rating: 1
benny279 has donated!
Driver side dipped beam not working?
Hey,
Once I fixed one problem another problem seems to crop up anyway, so my Driver side dipped beam doesn't want to work although, indicator, sidelight and full beam work? (driver side).
I've checked the fuses, they look okay checked voltage on the pin reads about 0.13v unless i'm doing it wrong as I never done a voltage check on a headlight in my life.....
I have changed bulbs 3 times and nothing and connector seems to be fine no corrosion no burned out cable, so this one has puzzled me to death....Need to sort it though cause its NOW the only thing holding back from an MOT pass!
Any advice or tips will much appreciated guys!
benny279 is offline Reply With Quote Quote
Old 20-01-2013   #2
Speed Reader of the Year!
Most Easterly Pandas's Avatar
Trader Rating: 2
Most Easterly Pandas has donated!
Re: Driver side dipped beam not working?
Was your fuse check just visual? Might be worth swapping them also
Also swap the relays and see if the problem changes sides
Most Easterly Panda's - Panda'ing in East Anglia
Stockest of mk2 Panda Parts, PM for any parts requests
1993 Classic Panda Selecta, 1989 Panda 750L,
2015 Kia Soul EV, 2009 Panda Eleganza & 2005 Panda Climbing 4x4 (LPG)
Most Easterly Pandas is offline Reply With Quote Quote
Old 20-01-2013   #3
Ziggy122 has donated!
Eggs Champion, Fruit Pairs Champion
punto uses a single relay to power both - its fused After relay
If 1 works then the relay is fine
But you can double check as the high beam is the same relay too!
And 0.13v at the headlight bulb connector is wrong
should be 12v
Ziggy
!!WANTED!! 3dr Mk2 Punto Roof Bars !!WANTED!!
Meet Bumble-Bee
Ziggy122 is offline Reply With Quote Quote
Old 20-01-2013   #4
Banned
Trader Rating: 1
Yeah passenger side works fine as in dipped, full, indicator, sidelight, with driver side just dipped isn't working, how do you check the voltages correctly as I think I may of done it wrong (wouldn't be a first!)
Old 20-01-2013   #5
Depends on the connector
But basically H7 is a 2 pin light bulb
push + into 1 pin
Push - into the other pin
With set to 20V (DC) you should get a reading of 12v IF the light unit works correctly
i had a dipped beam failure on the driverside
i ended up having the front end off pretty much
turns out it a wire had snapped (dunno how on earth like)
Only way to find out tho is to get the lights wiring and follow it back to the fusebox
which tbh - is a bitch of a job
ziggy
Meet Bumble-Bee
Old 20-01-2013   #6
Banned
Trader Rating: 1
Quote Originally Posted by Ziggy122 View Post
push + into 1 pin
ziggy
H1 connector?
Old 20-01-2013   #7
Ah h1 (googles)
Right - the wire you attach to the Bulb - thats +
The light earths (-) via the light casing
So + on the connector the the bulb
an - on the light casing (where metal meets metal)
Should give you 12v when lights on
if its its not - no power been recieved
So double check fuses
I even put Left onto right / right onto left the fault didnt move indicating a engine bay wiring loom fault not light cluster wiring fail
Ziggy
Meet Bumble-Bee
Old 20-01-2013   #8
Banned
Trader Rating: 1
Ah h1 (googles)
Ziggy
Sorry to be a newb here but do you mean that little connector on the side that looks like its soldered on? If you have a picture it'd be useful
Old 20-01-2013   #9
Banned
Trader Rating: 1
Scrap that idea, took it to a garage about half an hour ago checked connector, everything I did and nothing and they said it's a matter of tracing the wires to see if it's snapped/broken on it's route to fuse box.
Now my question, obviously loom starts at headlight and if someone can correct me does the loom go past the horn? Cause I can see one with two cables popping out for negative and positive for horn then goes right round to the fuse box. Is this the loom I need to check?
Old 20-01-2013   #10
Yes - if my memory serves me correctly the Headlight loom for the driver side has the horns in it too
Pull the whole wiring loom out - its alot easier with bumper and lights out tho
Ziggy
Meet Bumble-Bee
Old 20-01-2013   #11
Banned
Trader Rating: 1
Ziggy
I feel like an absolute tit! I forgot to put the fuse back in for driver side dipped beam! In the internal fuse back (inside the cabin) I blew a fuse about a few days ago and swapped the fuse over to power interior light and forgot to put a new one in for the headlight! haha, thanks for your help Ziggy! Guess it happens to the best of us!
Likes homeward liked this post
Old 20-01-2013   #12
Brain stopped play
homeward's Avatar
Trader Rating: 1
homeward is part of the official FF Events Team :)
homeward has donated!
Cool Re: Driver side dipped beam not working?
Quote Originally Posted by bennyyboy View Post
That's very honest of you... -- and so easily done...! At least you've remembered, and got it sorted...!
PS: Just noticed that this is my 1,000th post. Goodness me...!
Likes AndyRKett liked this post
1990 Panda 750L Formula '90: Pippin (26,131 miles; 47.18 mpg)
2009 Panda 1.2 Eleganza Dualogic: Pandora (55,670 miles; 47.87 mpg)
2002 Punto 1.2 16v ELX Speedgear: Priscilla (100,465 miles; 41.30 mpg)
homeward is offline Reply With Quote Quote
Old 20-01-2013   #13
Banned
Trader Rating: 1
Quote Originally Posted by homeward View Post
Haha, as I said it happens to the best of us!
And I'm no where near that post count yet!
Old 20-01-2013   #14
Trader Rating: 2
Sorry but
Only because in all honest that would be the sort of thing I'd have done
Likes homeward, benny279 liked this post
Old 21-01-2013   #15
Banned
Trader Rating: 1
Sorry but
First time I've ever done that, I guess there's always a first time for everything these days! And to be honest I'll never forget this!
Thread Tools
(T) HELP?! RH dipped beam not working :( PaulDynamic Bravo 8 08-11-2010 18:04
(T) Dipped beam not working payney1 Grande Punto 7 23-01-2010 14:26
(T) dipped beam lights not working andy16v Bravo / Brava 16 06-12-2008 23:43
(T) Drivers side (UK) dipped beam lamp replacement Ffoxy Stilo 0 18-02-2008 10:47
(T) Passenger side dipped beam keeps failing jcstanley Punto (Mk2/2b) 3 20-01-2008 16:09
