Hey,
Once I fixed one problem another problem seems to crop up :bang: anyway, so my Driver side dipped beam doesn't want to work although, indicator, sidelight and full beam work? (driver side).
I've checked the fuses, they look okay checked voltage on the pin reads about 0.13v unless i'm doing it wrong as I never done a voltage check on a headlight in my life.....
I have changed bulbs 3 times and nothing and connector seems to be fine no corrosion no burned out cable, so this one has puzzled me to death....Need to sort it though cause its NOW the only thing holding back from an MOT pass!
Any advice or tips will much appreciated guys!
