Technical Petrol fumes in car
Ian2011
Hi all,
Can you please help.
I own a 2003 fiat Punto 8valve active. When I return to my car after a trip out The inside of the car smells of petrol fumes. It is not that bad, but you can smell it. Is it a breather pipe and if so where is the pipe. I would appreciate any advice on sorting it out. Thanks in advance.
I had my cambelt changed the other day on my 2001 8v punto and had this problem. Under the airbox there is a wide black pipe that re-uses exhaust fumes from the engine and puts it back into the air intake. Make sure this is not loose or off completely. :>
Petrol is a distinct smell
Oil is a different smell - but i guess people can mistake it
The pipe is a poor fit - alot are like it
Ziggy
Thanks all for your help. Not quite got around to it yet but where does the breather pipe go to?
