- Jan 6, 2013
- 41
- 6
Been coming here a couple of years now, reading other Punto owners' problem-solving tips (always more helpful and cheaper than the garage!), but now it's my turn to show up with cap in hand. Get ready, this is a big one....
Just before Xmas, I cleaned my battery terminals and connectors on my Punto Mk.2 1.2 Sporting Speedgear (wasn't happy with how the car was only just firing up on cold mornings). I did it with baking soda in the usual way, then cleaned everything up and applied copper grease (already had a big tin, but no vaseline).
Since then, my problems have started...
1. The battery died after being sat idle for 2-3 days. Clock display worked, but engine wouldn't start, all I got was faint whine when key turned.
2. Engine management light then makes sudden appearance on dash. Strange it wasn't there before battery-clean!
3. Get free Kwik-Fit battery test, comes up as "74% unserviceable". It's a Halfords battery, still JUST under warranty, so luckily get free replacement. So, battery now brand new! But drain happens all over again after same 2-3 days sitting idle.
4. I order a multimeter, test the battery myself. Battery fine (fully charged) at 12.85v, alternator ok around 14v. Check battery for amp drainage, meter settles at 0.45amps. Ahh-ha! Start pulling fuses, one at a time, until pulling 70amp F1 maxi fuse (main dashboard power) drops readout to zero.
Haven't fallen asleep, I hope? I'm not finished yet......
5. Visible check of maxi fuse shows no damage, but I replace it anyway with new one, but no change, 0.45 drain still there!
6. I go driving at night, realise right-side headlight suddenly not working (all bulbs factory-fitted, had car from new since 2003, never had problem with bulbs before), so must have wrongly refitted F14 fuse (10amp) when checking drain. Next day, I pull fuse, check it, refit again - but no good, headlight still not working. I take out another 10amp fuse and put in F14 slot, but still no change - no right-side headlight.
7. Then, I get in car and start driving. Guess what? Red gearbox light flashing! I wonder which fuse I tested on F14 slot?? That's right! F23 gearbox fuse. Now, I've got flashing gearbox light and clicking sound when brake is pressed. AAAGGHHHH!!!!!
In short, has anyone got the foggiest idea what the hell I've done to my car, before I go all Basil Fawlty and proceed to beat it to death with the nearest tree branch?
I'm now in process of getting full version of MultiEcuScan, so I can hopefully shed more light on it, but I still think I did something to electrics when cleaning battery terminals.
Thanks for reading. You now have my permission to rest your heavy eyelids and recharge your own batteries!
