Hello everyone
I have read up on several thread about knocking noises but they all seem to be related to bushes etc. my issue is slightly different
Basically the old girl has developed a knocking noise per wheel rotation. doesnt matter if you go 2mph or 30 the knock is there and it can be felt if you hold the bandbrake whilst driving.
So, last night i took off the rear wheel and inspected the bub assembly, removed the front cover of the hub assy and everything looks fine... no obvious damage to pads, nothing looks like its moved or has broken.
i ensured that the bearing turned true and was not stiff in anyway and it seems fine.
does anyone else have any idea what this could be ? Im hoping to get my proper jack out later and jack the whole rear end up so i can look at both wheels at the same time but will have to wait till after work.
BTW this knock developed almost instantly ( i think when i drove the car in the morning it was not there and on the return trip it appeared.)
Thanks in advance
Tangoed
Thanks in advance
Tangoed
