Thread Tools
Old 21-05-2005   #1
cooling problem after changing coolant.
Hi!
I'm an owner of punto mk1 95 sx75
I changed my cooling fluid at last week to parflau 50/50.
I started to bleed my cooling system in two places.
1. Left up corner of the radiator. There is a bleed Nipple there.
2. At the back of the engine. On one of the two hoses (one of the hoses has a little bleed nipple).
I'm right?
Dose my bleeding process is right?
Or i forgot another bleed nipple somewhere else ?
Best Regards L.A
Lethal_Acid is offline Reply With Quote Quote
Old 21-05-2005   #2
Trader Rating: 10
dave has donated!
Re: cooling problem after changing coolant.
yep thats them, open both, fill coolent right to top past max, squese all hoses, repeat untill loads of bubble free collent comes out the back bleed screw, then fill right to top again completly remove rad bleed screw, let coolent run into a bucket (or on the floor if you bad) untill it goes down to max mark quickly put screw back, make sure coolent still at max, replace cap, check bleed screws are tight, run engine till hot (fan comes on), turn off let cool pref' over night, check level n re fill to max
Old 21-05-2005   #3
10x man!!!
GREAT EXPLANATION!
Tell me plz.
in a hot country will be difference in a motor temp if i'm using coolant or ordinary water in the cooling system?
Old 21-05-2005   #4
Forum Moderator
T14086's Avatar
T14086 has donated!
Use coolant! it's a inhibitor aswell as a coolant,most coolants these days are made for hot/cold climates.
Old 22-05-2005   #5
Trader Rating: 10
dave has donated!
Quote Originally Posted by T14086
never use just water it will corode inside of your head away
Old 22-05-2005   #6
Forum Moderator
T14086's Avatar
T14086 has donated!
"never use just water it will corode inside of your head away "
Ford(dont know if others do aswell)use clear anti-freeze so it aint easy to tell if anti freeze is in there
Thread Tools
(T) Punto cooling problem GaryRichards Punto (Mk2/2b) 6 29-10-2007 15:48
(T) Heater and coolant problem colonel-shoe Punto (Mk2/2b) 9 18-03-2005 03:52
(T) cooling problem on my gt punto_gt_lad Punto (Mk1) 1 06-01-2004 02:43
(T) Coolant changing colour? Idge Stilo 8 02-08-2003 21:53
(T) Cooling System Problem Punto 60SX 1999 andyr Punto (Mk1) 2 10-05-2002 04:51
