Hello guys,
Firstly I'd like to say I'm new to this forum so I really hope that this post in the right place etc! Also I have read so many 'Heater fan problem' posts on here and I understand its been done to death, but this is something a bit different I think!!
I have a 2004 1.9 HGT Multijet JTD Punto (Mark 2b) and basically the fan heater has stopped blowing. It has the full spec dual zone digital climate control until WITH air conditioning just in case that makes a difference. The control unit seems to be functioning absolutely fine; you can adjust the temperature, control the direction of the blower, put the air con on etc etc...but there is no actual blow, ie the heater fan does not fire up at ANY speed. It has 10 different speed settings because of the climate control unit and none of them work.
Today I have had the fan motor out of the passenger footwell and tested it. All seems to be working fine. My dad knows an auto electrician well and we have taken him the fan motor which he tested and said it was all in good working order. He said its most likely a problem with the resistor pack, which he then tested and concluded it was ok (as far as he could tell because he didnt really understand the resistor). We then took apart the dash board and checked all the connections on the back of the digital climate control system, and they all seem connected fine and in good working order.
So I phoned Fiat and they wouldn't give me any advice, they just said to book it in....but obviously without extending my overdraft by a considerable amount, letting Fiat do hours of exploratory work isnt really an option They did however quote me on a new fan motor which was £150 + vat (unbelievable!!).
So basically I need some advice. I also popped into a scrap yard this afternoon to see if I could get another fan motor and resistor just to try. I looked at a 53 plate 1.2 Petrol Punto mk2b and it was a different motor and resistor altogether from my HGT. Do I try to get my hands on another resistor to try or is Fiat going to be the only route? Basic internet searches show me nothing when it comes to the resistor pack I would need. Also just thought I would mention, the side lights do not come on when I try the fan so its not an earthing issue as stated in some posts. My dad has tested the power feeds to the motor with a multimeter and from the climate control unit to the motor and the voltages increase with every higher setting on the fan, so all seems to be good!
Any help at all would be appreciated as this is a problem that needs fixing, 2 days without a fan in a steamed up car are enough for anyone :/
Thanks a lot
Jack
Thanks a lot
Jack
