Hi
I have a 2003 Mk2b Punto and the front wipers have developed a fault.
The intermittent, normal and washer settings (the washer’s still spray water) no longer work and the single push only works if you hold the stalk up.
The only setting that works is the fast speed and even then it will not return to the stop position when you cancel the wiper.
I've checked the linkage and everything appears to be fine.
From looking through the forums I’ve seen various suggestions for similar problems from relays to new stalks and was wondering what the best course of action was.
