So this Saturday I finally got round to stealing my dads garage and fitting my ported and polished cylinder head with high lift cam that I brought from Brin a month or so ago.
Didn't have too many problems as I've spent a while planning my steps to stop my self going round in circles.
One of the original plans was to paint the engine black and red but after looking into the time to remove engine I settled on painting the cylinder head and rocker cover, however when I had my engine cleaned last Monday it would appear they "missed" several bits including the rocker cover so I may go for a polished rocker cover from MrFixIt and the paint the exhaust manifold black to match the head.
Anyway, the first problem was the HT Lead on the spark plug for cylinder No. 1 broke and the metal contact remained on the spark plug. The second was access to the engine mount bolts on the side of the cylinder head, to get around this I left the last part of the mount on the head and disassembled later.
Before separation I rotated the bottom crank until the timing marks on both cranks lined up, I quickly realised what is meant by being 360 degrees out as the bottom crank turns twice for every rotation of the cam shaft.
I also inspected the timing on the new head and cam as the crank was changed to be suitable for use with the crank sensor, measuring and comparing the location of the lobes on the heads it was clear the head had been set up timed ready for bolting on.
My dad expected the cylinder head and block separation to be difficult due to age of car, if it wasn't for the fact that the bottom end is from an Punto 60 SPI (unsure when replaced) he probably would of been correct but it came apart surprising easily. I don't think a torque wrench was used when the engine was replaced as I had no difficulty in removing any bolts.
Once the head was off I blocked off the water, oil and bolt holes. Also i greased each cylinder to prevent anything falling between the piston and cylinder. I then used some degreaser and a Stanley blade to remove any left over gasket and residue, judging from the condition of the gasket and the colouring on the matting surfaces it would seem the gasket was starting to fail. I then took a sponge and degreaser to the piston heads removing as much grime as possible, if any ones considering a gasket or head change get some emery cloth, it would of been a lot easier to clean up and probably would of done a lot better.
Reassembly went well, 6 of the studs for the exhaust manifold came out with the nuts during removal but the nuts came off easily one the studs were in a vice. The only crap bit was getting the phonic wheel back on the bottom crank, the bugger just wanted to spin the crank. Help with this came from the least likely of people, my sister. The broken HT Lead I repaired (bodged) by pushing back in and checking it made contact with the cable with the help of a torch.
Once everything was back in I started it up. it took a few turns if the starter and it went, and if I'm honest it sounded absolutely bloody awful, it would run for a short while and then cut out, if I gave it gas it would cut out. Unplugged the damaged HT Lead and it wouldn't even start. It sounded as tho it was only firing on 2 cylinders, my first thought was that when cleaning the piston heads the crank went round 1 too many times. By now it was 10:30 and the mrs was screwing so I got a lift home to sleep on it and browse the net.
So Sunday I got some HT Leads from halfords as I needed a new set anyway. On the evening I got picked up and went for round 2.
I took my old laptop and OBDII lead, although only free versions of software, I got 2 error codes, one being a fault in coil pack B primary/secondary circuit. The other was lamba sensor bank 1.
The first thing I did was check all cables and connections, i then changed the HT Leads and it ran a bit better but still terrible. I had replaced the bottom crank sensor with a 2nd hand one I purchased as where the wire joins the cable it looked as though it had be scrapped along the floor and you could see the inner wires. I put this one back on and it ran about the same.
Next I went for the timing and soon discover the top crank was out anti-clockwise by about 5 teeth!!!!! I realigned and put back together, however I found I needed to rotate the top crank half a tooth to get the belt on with the tension remaining on the belt at the front of the engine.
This time I started it up it ran and sounded a lot better, still only 90% but so much better, no cutting out on idle or when pressing the accelerator. The only way I can describe it is that it sounds like an old motor bike, certainly a head turner. After letting it warm up I took it round the block (steadily). At idle it sounds bad, accelerating not so bad, driving at a steady speed you can hardly hear it. I found the temp gauge shot up to just over half then rapidly dropped to 1/4, I assume this was due to the thermostat opening allowing water to fill the cylinder head and into the heater matrix.
There was a bit of smoke but I believe this was due the cylinder head paint and the small but of oil I spilt on the block/exhaust.
Although it runs it is slightly bad and still needs TLC. A further search of the net suggests a head skimmed by the max of 2.5mm can throw the timing off on top crank by between 6 and 12 degrees depending on number of teeth etc. Various debates but no real answers.
I believe the timing may still be out by a tooth in either direction.
Today I checked the water and oil, water needed topping up and bleeding again. Also I noticed oil all along the rocker cover gasket and coming from where the coil pack holder meets the head. I've purchased some sealant as I intend to seal the coil pack holder and all along the top of the head as this seams to be a common issue with these engines.
Essentially I need some advice. Do I "fine tune the timing" or am I looking in the wrong place?
Sorry for the lack of links and pictures, currently on my phone so ill have to post later
