Hi Guys,
Posted alot recently; had numerous issues - first it was clutch, then the thermostat and then the sparks/leads.
Just thought I'd get a second check as I'm about to drive about 75miles and don't want to get stranded along the way!
The Problem:
My poor Punto seems to still be slightly misfiring - despite the garage doing a HG pressure check (came back fine), and replacing the Sparks/Leads. - This only happens at a standstill and on LOW revs.
I've recently replaced the thermostat - wasn't a hard job, but its drained about 3 litres of 50/50 anti&water. I've been topping up each day; but it still seems to go down... I've checked for leaks - and nothing is leaking as far as I can see - but I do hear the occasional gurgling sound when I turn my engine on.
Since replacing my thermostat, my temperatures fine; no problems with that, doesn't overheat, literally stays at midway during all speeds.
Anyway; I've currently got it at the garage at the moment, hoping they can figure out the cause - anyone have a quick diagnosis as they've said they MAY not get me in today but I need to travel!
The Problem:
