Thinking of replacing my stock (non-foglight) Mk2 headlamps with a pair of something like these (although I have found similar ones on eBay at £129.95 and £149.95).
The reasons being:
I digress, though....
The reason I mention the Isuzu is that, when we moved here, I installed some nice angel-eye spotlights on the front, that came on with the main beam. (The angel-eyes came on with the ignition....) They were just about perfect -- especially as, being on a 4x4, they were mounted quite high up -- lighting the road for quite some distance; and I'd therefore like to replicate this (as close as is possible/pragmatic) on the Punto.
A handful of caveats:
The reasons being:
- We live in the middle of the countryside: and a lot of the roads around here are unlit, and often edged with large clumps of trees and large hedges, etc. (so can be murky, at the best of times...).
- There are also the associated problems with suicidal wildlife...!
- I'm also a bit of a fan of DRLs!
- As mentioned in the DRL post, I like to be as safe as I can, when driving.
- There isn't really anywhere to mount additional spotlights, though; and I don't want them protruding beyond the front of the bumper, of course. (Additionally, I don't think they would suit the look of the Punto, anyhoo.)
- There are no blanks in the bumper grilles for mounting any sort of light. (However, I am thinking of replacing the front bumper -- which is slightly damaged -- with a Sporting one; and I have seen, somewhere, a rather neat installation of a pair of lights in the grille underneath the number plate: although this is probably too low for my purposes....) I can't afford this, though...!
- I'd also like to avoid adding an extra switch in the cabin: preferring all extra lighting to come on automatically (as above) -- using relays, if necessary.
- I'm not particularly keen on going down the HID route, either -- unless someone can persuade me otherwise (my main concern is the legality -- or otherwise...) -- and therefore I'm simply just popping in 5,000k Xenon bulbs, to begin with, until I make my final decision.
- Whether this is a path worth progressing down.
- What you would do in my shoes.
- If there are any particular products -- i.e. replacement headlights, additional lighting -- that you can/would recommend -- either because you have/had them fitted; or know someone who has, etc..
- Any pitfalls I must/should avoid, when replacing the headlamps (e.g. not forgetting to transfer the height-adjustment motors...).
