kostas013
- Aug 20, 2012
- 163
- 26
hello everyone i am kostas from puntoclub.gr and i just signed in your great forum
heres is my 2000 mk2 5door HLX
mechanicaly i have wire grounds, omp filter in ram air from c2vts, cams from mk1 sporting and soon the valvetrain from the same car, ECU tuned by RevLimit, lighter flywhell, body throttle from 1,4 Punto mk2b Sporting, exhaust with 48 out and 45 in diameter (45out and 42 in the standard) with other cat back from remus, a fume conteiner (i think this is its name in english:yum, and iridium ngk sparks, and a litle shorter gearbox from seicento sporting!!
from the inside now... italian semibucket with sparco belt in drivers sit, sparco pedals and sparco shift, ayto meter gauges (oil temp and oil pressure), Punto badge in front of co driver, a litle better sound, removed the nets from front doors, and some led in the console...
i have also front strut brace from Sparco, rear handmade strut brace, and in about 5-6 days i ll have the ultra racing kit for mk2
i also have front powerflex silent blocks from punto GT...
my brakes are standard diameter from Brembo and black galfer pads and galfer Stainless Steel Brake Lines with motul 5,1 brake fluid...
my rimms are unfortunately 14'' but they are very light and with 26 offset (if ya know what i mean ) and it is planed to change in 15 with toyo R1R soon...
last koni yellow absorbers (with adjustable camper) with 3cm eibach springs, also intresting springs was from HGT, they worked very good with the car but cause i am lighter than an HGT i was HIIIGHHHHHHHHH xaxaxa
and a video from my car
think i didnt forgot anything
Greetings from Greece!!!
