Hi Everyone
I’m fitting some parking sensors to my Punto Mk2b. I bought the sensors as I want to spec-up my car with genuine Fiat accessories and gadgets! Just thought I’d clear that up before I get any stick about not being able to park!
The sensors are the Fiat Lineaccessori SP4 made by Meta System Front and Rear sensors, which were available as an optional extra from Fiat dealership. They are slightly different from the factory fitted ones which have 4 sensors at each end rather than the 2 described here.
There are 2 modules, one for the front sensors and another for the rear. Both are labelled as ‘SP2’ if anyone is familiar with this system.
The sensors, buzzers and power cables clip into the modules very straightforward with pin connectors however I am having trouble with the wiring of the power cables to the car’s fuse box located in the drivers side compartment.
Front Sensors
The Front system has 4 wires from the power cable.
1st – Grey wire, which is to be connected in the left hand side of the Fuse box (+12 Reversing Light, in the 32-pin connector) (*Where the main loom is connected with the purple plastic retaining clip*)
2nd – Red Wire, connected to the blue wire (+15 dashboard key switch in pin 11 found centrally at the rear of the fuse box)
3rd and 4th – both connected to earth into pin 20 found on the right hand side of the fuse box.
Rear Sensors
The rear module seems to be pretty straightforward. There are only 2 wires to power the device, one red and another black. The red connects to the red and white reverse light wire and the black connects to the black wire both found at the light’s connector.
Any advice for the wiring would be greatly appreciated!
Front Sensors
Rear Sensors
