chicknchock
- Aug 6, 2012
- 7
- 2
Hi Everyone
we bought our Punto about 6 months ago and the air filter wasn't secure, i used a cable tie to strap it down however i need a more sensible solution. pictured is where its snapped from the bolt and wondered if anyone had any advice on how to fix this?
the other bolt on the other side of the filter is perfectly fine but its kinda rocking
Issue two is the radiator fan, it simply doesn't spin and I wanted to try changing the fuse first before taking it to a garage, can someone please point out the correct fuse to check? I have ordered a haynes manual and still awaiting its arrival.
here is the issue three.. i believe that to be the rocker cover?
